Author Topic: Strange MFA Problem  (Read 1922 times)
Offline Mars Attacks
Strange MFA Problem
« on: 17 February 2009, 15:43 »
Hi, bought a sportline recently, enjoying having a MK1 again, but trying to get through a few niggles at the moment.
The MFA seems to be playing up. Firstly there is never any oil temperature displayed just ---- during every trip, even when at full running temperature, so is that likely just a case of changing the oil temp sender on the oil filter housing? Exterior temperature reading works fine.
However the weird problem that i am having is that when i set off on a journey the MFA displays --/-- for Miles driven, average speed, and mpg for at least 40 odd miles then all of a sudden it kicks into life and starts to show figures. a reset from that point on and it all starts to work ok. leave the car over night and it does it again --/-- all the way. Anybody seen this happen or know of a reason/fix?
This is probably unrelated but i did notice my speedo is showing the speed out by 5mph, noticed this on the way home from buying the car as i had the sat nav on as well and they were out of sync. Is this just a new speedo cable needed?
Any help would be appreciated.
Thanks
Offline raferackstraw
Re: Strange MFA Problem
« Reply #1 on: 17 February 2009, 20:36 »
re the speedo issue i think you,ll find most older cars are out by a similar amount
im sure i have read somewhere on here it is normal amount of 'factory' built in error
aftermarket wheels i.e. larger than originals will also affect speedo reading  :wink:
as for the mfa i personally wouldnt bother with it i never did use it when i owned gtis back in the early 80s your better off getting vdo guages to monitor oil temp etc
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
