Author Topic: clunking noise after fitting coilovers  (Read 1046 times)
Offline mk3 tdi
« on: 16 February 2009, 23:34 »
i ve just fitted a set of coilovers i got cheap - used - and they are making a clunking noise when i go over bumps, i think its the front, i dont think its the coilovers as i know the guy who i got them off and he said money back if they are faulty -
is there other things i can check ?
Offline shepgti
Re: clunking noise after fitting coilovers
« Reply #1 on: 16 February 2009, 23:44 »
exhaust knocking on rear beam? sump hitting the ground? wheels catching arches?  how low have you set it?
« Reply #2 on: 17 February 2009, 07:42 »
Also worth checking your top mounts.
Offline Shady Pioneer
  • graphic designer.
« Reply #3 on: 17 February 2009, 11:52 »
I had this, and it was my top mounts, best thing to do I found to be sure where the noise was coming from is go over some speed bumps and see if you can listen out for where it's coming from.
I found when my front end went up the speed bump and don't, it was more noticeable from the front :)
Offline mk3 tdi
« Reply #4 on: 05 April 2009, 20:30 »
i ve got it sorted - the mechanic had left the top mounts loose on the front - hope it didnt cause no damage :undecided:
