Author Topic: Swapping shocks will these be ok?  (Read 1255 times)
Offline Steve_B
« on: 16 February 2009, 19:22 »
Need to get me some spring compressors to swap the front shocks and saw these on amazon
http://www.amazon.co.uk/Draper-68615-Coil-Comessors-2/dp/B0001KA0JU/ref=sr_1_3?ie=UTF8&s=diy&qid=1234811072&sr=8-3
It says they will open up to 220mm, will this be enough?
Steve
Offline Benrevs
Re: Swapping shocks will these be ok?
« Reply #1 on: 16 February 2009, 19:49 »
Tbh i have never used compressors.. :lipsrsealed:  If you are swapping standard for standard then you will be fine with just a bit of caution.
Offline sidecarphil
« Reply #2 on: 16 February 2009, 19:51 »
yep they'll work
be carefull not using them when undoing the spring top i got a nice scar on my chin after not using them once
mind you it was a renault leguna spring and they are about 4 miles long !!!!
Offline Steve_B
« Reply #3 on: 16 February 2009, 20:17 »
Cheers for the replies :smiley: So I fit the compressors before undoing the top mounts?
Have been reading the haynes, is it worth getting new nuts for the strut bolts?
Offline rodz22
« Reply #4 on: 16 February 2009, 20:28 »
http://cgi.ebay.co.uk/TWO-Heavy-Duty-COIL-SPRING-COMPRESSORS-for-22mm-Socket_W0QQitemZ230307930216QQcmdZViewItemQQptZUK_Hand_Tools_Equipment?hash=item230307930216&_trksid=p3286.c0.m14&_trkparms=72%3A1700%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
these seem just as good and cheaper
little tip
dont allways believe what the haynes manual tells you
when you replace the strut bolts just put a dab of threadlock on the bolt  :wink:
Offline Steve_B
« Reply #5 on: 16 February 2009, 20:39 »
got free delivery from amazon so they work out the same.
cheers for the tip about threadlock rodz  :smiley:
Offline Steve_B
« Reply #6 on: 21 February 2009, 19:58 »
After a LOT of running around getting tools together (that's what you get for lending them to friends), managed to change one of the shocks today. Not the most impressive result but it is my first time, the other one should be quicker tomorrow.
In case anyone is interested, I managed to get the nut for the top cap off using the following household objects:
7mm allen key
13/16 spark plug socket
mole grips
the lever from my trolley jack
Probably not news to some of you but I was impressed that it worked!
