Author Topic: 80k service due any tips?  (Read 7065 times)
Offline nadlad
  • Building Surveyor MRICS
« on: 16 February 2009, 19:05 »
as above on my 150tdi anything in particular to change
i was thinking of doing the glow plugs, oil, fuel filter and air filter the cambelt has been done. maybe change the brake fluid aswell?
<<<Big Build Thread>>>
Offline player.777
Re: 80k service due any tips?
« Reply #1 on: 16 February 2009, 19:13 »
which glow pugs do you use?  do uprated ones makes any difference to overall performance like better spark plugs??
Offline Steve_PD
« Reply #2 on: 16 February 2009, 19:16 »
I done my 80k service before christmas and done oil, oil filter, air filter, pollen filter, fuel filter and brake fluid  :smiley:
Offline nadlad
« Reply #3 on: 16 February 2009, 19:17 »
dunno mate i just thought maybe its time to change the glowplugs or peopel not normally change them?
Offline nadlad
« Reply #4 on: 16 February 2009, 19:19 »
cheers steve ill do all them then....... i usually change all of the obove every 10k except for fluids and pollen (every 20k) even though i think vw say every 40k for fuel filter orwhatever but for the sake of a tenner its cool?
Offline Rhyso
« Reply #5 on: 16 February 2009, 21:04 »
no point doing the glow plugs - i believe they are only used during the ignition cycle and then redundant when the engine is warmed up
http://en.wikipedia.org/wiki/Glowplug
it won't give you a performance benefit like changing spark plugs on a petrol engine
Offline Steve_PD
« Reply #6 on: 16 February 2009, 22:06 »
I always change everything apart from the brake fluid and pollen filter
Offline Ridg
  • TDI - Soot Happens!
« Reply #7 on: 17 February 2009, 09:37 »
off the top of my head, 80K should include all the filters, oil, pollen, fuel, air, be worth checking your brake fluid (every 4 years) all the joints should be greased etc.
the only time you should change your glow plugs is when they fail, as i've said before buy yourself a copy of the Haynes manual as that details everything that needs to be done on each service
Offline player.777
« Reply #8 on: 17 February 2009, 14:07 »
Ok nice one matey. cheers
Offline nadlad
« Reply #9 on: 18 February 2009, 10:21 »
what about in terms of oil vw use quantum pd oil is there anything better than that to use?
