Author Topic: MY HEAD IS HURTING !!!!!!!  (Read 1533 times)
Offline rodz22
« on: 16 February 2009, 13:05 »
PLEASE HELP ME BEFORE I LOSE IT AND MY MATE SMASHES HIS CAR UP WITH A LUMP HAMMER.
HAD A GO AT PUTTING A HYDRAULIC CLUTCH SETUP ON MY MATES MK 2 GOLF VR6
USED ALL NEW CYLINDERS AND MODIFIED THE MK2 PEDAL BOX TO SUITE THE MK3 HYDRAULICS
BLED THE WHOLE SYSTEM
CHECKED FOR LEAKS
CANT SELECT GEARS
PLEASE HELP  :cry: :angry:AS IT IS GOING ON FIRE IF IT DOESNT WORK LOL :laugh:
Offline The Mighty Elvi
  • I'm better than you today.
Re: MY HEAD IS HURTING !!!!!!!
« Reply #1 on: 16 February 2009, 14:03 »
Offline Roverdose
  • So long and thanks for all the fish!
« Reply #2 on: 16 February 2009, 14:14 »
Jesus man, i've had the same thing whilst doing my jetta, done my rover gearbox once and every time i put her on her wheels oil would come pissin outta the driveshafts, ended up kicking my door and wing in until i realised that hanging  behind my car was a rather large punch bag! :(
If its got a slave cylinder check that thats moving freely!
Offline rodz22
« Reply #3 on: 16 February 2009, 20:11 »
Right,  slave cyl is brand new moves freely no catching or shuddering so thats not it
i am calm but my mate is a bit volatile unfortunatly
and seeing that his golf has been a bit of a money pit recently he is very peeved off
can any one please measure from the clip on the pedal to the start of the master cylinder
think it might help us in putting this demon to rest
thanks for the help  :cry:
Offline bigwes
« Reply #4 on: 16 February 2009, 21:48 »
from wot hear a corrado pedel box and servo setup is the way to go shud fit pretty much straight in.  :nerd:
Offline Diamond Hell
  • Opinions я Us
« Reply #5 on: 16 February 2009, 22:27 »
Leave the Golf2 pedal box in there and fit a Seat clutch cable, actuator arm and the cable mounting bracket from an early 90's Passat.
Cable-actuated clutch - no worries.
Offline rodz22
« Reply #6 on: 17 February 2009, 09:03 »
cable clutch was great but is was very heavy and kept snapping cables hence the brainwave of fitting hydraulics !!!!!!! . wish i hadnt bothered tbh.
as for thecorrado pedal box cant find one anywhere.
apparently the seat cluth cable is 150 quid to buy ??????
Offline sidecarphil
« Reply #7 on: 17 February 2009, 09:05 »
are you sure there is nothing inside the clutch seized ??
if it was snapping clucth cables and now the hydrilics dont work  :undecided: :undecided:
Offline rodz22
« Reply #8 on: 17 February 2009, 13:08 »
Hmm i hope not coz i really want out on this one  :sick: getting fed up with it
http://
has anyone else tried this sort of thing ????????????????
Offline monzablue16v
« Reply #9 on: 17 February 2009, 17:59 »
Have you got the pin that goes in the gearbox end cylinder in there and the correct way around? do the hydraulics work if the master cyl is removed from the gearbox?
