Author Topic: Need some help With Brake conversion  (Read 1322 times)
Offline BiGgmike92gti
« on: 04 July 2004, 06:08 »
Hey guys whats up im new to the vw scene im a mechanic though so i know what im doing i just need to know whats the best thing to do
Ok i have a 92 gti and i need a new wheel (front) bearing and since i have to take a whole lotta stuff of, Hey why not doa brake conversion I would like to know whats the best conversion to do.  I heard theres dual pistons cailpers?  just give me the best conversion and the size of the rotors.
Also listen to this my wheel almost fell off  3 lug bolt just ripped outta the rear drums which also i have to ask whats the best rear disc converion
please help me out guys thanks and do some explaining to
-since im new ill be asking for more help
Offline mk1
Re:Need some help With Brake conversion
« Reply #1 on: 04 July 2004, 10:07 »
If you change the front hubs to 16v ones you can then fit 280mm discs and callipers from a G60 or mk3. You should have discs on the rear, if not they are a straight forward conversion covered in the mk1 forum.
Steve.
Offline Dizzie
  • Make friends with your fast
« Reply #2 on: 04 July 2004, 15:37 »
I think you can get a Wilwood 4 pot caliper setup that runs with 280mm x 22mm discs for about ?180 if you want even more brakes.
Make sure you change the master cylinder at the same time.
