Author Topic: Amp or speaker or speaker wire problem?  (Read 3526 times)
Offline Adam
Re: Amp or speaker or speaker wire problem?
« Reply #10 on: 16 February 2009, 15:07 »
You have swapped it back and it works? Sounds like it was loose or slightly grounding somewhere.
Glad you got it sorted.
 (Any luck on the two circular things on your pilers?)
Down Hill From Here.
Offline Shady Pioneer
  • graphic designer.
« Reply #11 on: 16 February 2009, 15:50 »
I'll be keeping an eye on it for now, I haven't swapped the speakers back round though, worth doing? I'll get pics of them bits for you for tonight buddy :)
Offline LazyLunatic
  • MK3 20VT Project
« Reply #12 on: 23 February 2009, 21:01 »
check wiring and then check it again. but sounds like i'm too late for this one. sorted :afro:
as regards to the rca outputs. normally it is best to use the sub output for the sub, as the headunit controls the sub, through the sub volume control in the menu, if you get what i mean. you can adjust the sub volume by going to the menu on the headunit. so whatever is hooked to the sub rca will be controlled by this. if that makes sense :huh:
LL ;)
  • graphic designer.
« Reply #13 on: 23 February 2009, 21:04 »
LL ;)
All is cool now man, cheers anyway. As for the sub RCA, don't worry, I got that sorted on day one lol! It's nice being able to crank up the bass just like that when you want too :)
