Author Topic: brake pedal 'pump up' question  (Read 1499 times)
Offline paultownsend
« on: 15 February 2009, 13:52 »
91 '8v gti
im putting in the goodridge hoses next week after 2 years of mot advisories  :lipsrsealed:
when i changed to the front g60 set up, new pads and disks all round (pagid f/r, brembo) i used the 22.2mm m/c. i also used an eezibleed system and the 2 man method.
the stopping power is massive, but still a spongy pedal. but, i find if i pump the pedal gently a few times the feel is very firm. which i like. but then it returns to the spongyness!
is this a m/c, vacume, or possible servo problem?
thanks chaps
Offline shakeyjake
Re: brake pedal 'pump up' question
« Reply #1 on: 15 February 2009, 13:56 »
what servo do you have on it?
Offline mattkh
« Reply #2 on: 15 February 2009, 13:57 »
Hi
You dont mention anything about the brake fluid.
Offline Dolly
« Reply #3 on: 15 February 2009, 14:19 »
ive fitted front G60's and rear mk4s with braided hoses all round i clamped the bias valve and pressure bled it twice. the pedal is pretty solid until i unclamp the valve and take it for a drive its really dangerously spongey. should i manually bleed it old fashioned like, or is it more likely the valve has had it on the rear?
im definatly not loosing fluid.
« Reply #4 on: 15 February 2009, 14:59 »
sorry new 5.1 fluid was put in. and the std 8v pb gti servo was retained. and the compensator was clamped fully open  :smiley:
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #5 on: 15 February 2009, 18:30 »
The servo will not cause a spongy pedal. It only assists in braking force. A spongy pedal means you have air in the system and needs to be bled out.
« Reply #6 on: 15 February 2009, 18:35 »
is a proper pressure bleed at a garage the only 'proper' way to go?
Offline danny_p
« Reply #7 on: 15 February 2009, 18:40 »
i've allways managed to bleed them up the traditional way.    vaccume bleediing is optimal tho
all the VW's have gone bar 1.
Offline Dolly
« Reply #8 on: 15 February 2009, 22:13 »
i pressure bled it, then drove it and then re-pressure bled. im definatly going for the traditional approach next time.
Offline DarnPB
« Reply #9 on: 16 February 2009, 08:18 »
I have never used the pressure bleed system. Always with one in the cock pit, and me at the wheels, shouting, 'down', then 'up', then 'down', then 'up'........
I have used back bleeding before, albeit on light aeroplanes which works for me. You remove some of the fluid from the reservoir, then with an oil can filled with brake fluid, fit the end of the tube to the nipple, crack the nipple open, then pump until all the bubbles come up through the reservoir. Then keep pumping until the reservoir is up to the full limit. :smug:
