Author Topic: head unit problem  (Read 1434 times)
Offline steve85
head unit problem
« on: 15 February 2009, 11:01 »
ive just bought a sony cdx-gt630ui head unit and fitted it myself. the only problem is everytime i take the key out of the ignition the memory is lost on the radio and all the settings i change. noticed that there is a two pin plug that went into the cd player of the old double din gamma system but no place to plug it in on the sony head unit. is this the problem or have i overlooked somthing.
any advice welcome
Offline dai-cymru
  • 1989 MK2 16V
Re: head unit problem
« Reply #1 on: 15 February 2009, 11:02 »
on after market units you got to swap 2 wires over will try and find the link for you
Offline dai-cymru
  • 1989 MK2 16V
« Reply #2 on: 15 February 2009, 11:04 »
you have to swap the red and yellow wires over  :smiley:
Offline steve85
« Reply #3 on: 15 February 2009, 11:05 »
in the plug or on the split in the wire m8
Offline speed_freak
« Reply #4 on: 15 February 2009, 11:08 »
the wires should pull apart in like a bullet style connector and just swap them there
Offline dai-cymru
  • 1989 MK2 16V
« Reply #5 on: 15 February 2009, 11:10 »
have you got the iso connector? if so swap it around in that you can pull the pins out. had to do it with the mrs leon
Offline troublestarter
« Reply #6 on: 15 February 2009, 12:29 »
the sony will have a bullet on the red and yellow wires just swap them round no need to remove any pins from the iso plug
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline vdub_adz
« Reply #7 on: 15 February 2009, 12:41 »
as all said above just swap them over. somethink to do with mk 4s not having a 12v supply to keep the settings but swapping them over sort this problem. let us know how u get on
Offline jonnyturbo
« Reply #8 on: 15 February 2009, 15:47 »
Yup two minute jod swap the yellow and red wire around. So you have red going into yellow and yellow in to red. Then it will keep its memory  :grin:
