Author Topic: Steering Rack  (Read 10064 times)
Offline Steve_PD
Steering Rack
« on: 14 February 2009, 23:39 »
My steering rack is fooked anyone know how much they cost to buy and to fit??
It will be going on the warranty (hopefully) also got to replace the front wheel bearings.
Its just one problem after another with my golf  :angry: I still love it tho  :cool:
Offline MrTurner
  • Facelift leon cupra
Re: Steering Rack
« Reply #1 on: 15 February 2009, 00:10 »
Are you sure its defo the rack?  I had to replace the rack arms, only around £10.  Full rack is more like a ton I think.
Offline Steve_PD
Re: Steering Rack
« Reply #2 on: 15 February 2009, 00:19 »
yeah there's PAS fluid coming out the rubber cover and going all over my wheels  :angry: seem a rack for £130 on ebay, got to phone the warranty company asap and see if its covered
Offline MrTurner
Re: Steering Rack
« Reply #3 on: 15 February 2009, 00:30 »
Got to be worth a shout.  Warranty should not pay out on wear and tear, but I wouldn't think a rack is wear and tear!
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
Re: Steering Rack
« Reply #4 on: 15 February 2009, 07:57 »
Time for an R32/TT 225 rack, :P 8)
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Grand Master Patch
Re: Steering Rack
« Reply #5 on: 15 February 2009, 08:41 »
What he said,you only need the steering rack and track rods arm things :smiley:
Also look for Cupra R in your search
Offline Steve_PD
Re: Steering Rack
« Reply #6 on: 15 February 2009, 10:08 »
If I got it done on the warranty they will only use the correct part  :cry: also dont fancy buying a used one for it to only break again  :angry:
Offline dai-cymru
  • 1989 MK2 16V
Re: Steering Rack
« Reply #7 on: 15 February 2009, 10:22 »
Steering rack is quite involved, need to drain fluid, unbolt banjo bolt from the P.A.S pipe, drop the subframe and rack clamp bolts and undo the pinch bolt on the bottom of the steering column undo track rod ends
Offline richw911
Re: Steering Rack
« Reply #8 on: 15 February 2009, 13:57 »
I so unfortunately  i was right steve  :cry: :cry: :cry:
OEM from VW - i was quoted  wait for it - £400  :shocked: :shocked: :shocked:
I got a reconditioned unit for £150.   :wink:
Offline northeast_gti-t
  • "1.8T AGU"
Re: Steering Rack
« Reply #9 on: 15 February 2009, 14:41 »
i wonder which the dealer will fit as the cars under warranty  :laugh: i would ask for a new vw part to be fitted but you know how stealers are :rolleyes:
2000 Mkiv GTi 1.8T AGU
