Author Topic: help with alarm  (Read 2088 times)
Offline carrie
  • i can see into your soul and its not good
help with alarm
« on: 03 July 2004, 16:38 »
does anyone have or know where i can get a wiring diagram for a vw votex car alarm  ???
part number 044 054 612 A
as i have two and would like to fit one to my car.
thanks in advance for any help with this :)
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline Dizzie
  • Make friends with your fast
Re:help with alarm
« Reply #1 on: 03 July 2004, 23:15 »
if only it was that easy.
to be thatcham approved about 10 wires have to be completely black  :(
Unless yours are coloured wires with black sleaves there's no way you'll find it on the net. unless you have a very good friend that installs them and could help out. If you could all the theives would know the alarms inside out. :(
soz :)
Mk4 Golf 150PD
Offline carrie
Re:help with alarm
« Reply #2 on: 04 July 2004, 16:07 »
there mostly coloured wires its the vw fitted alarm which was option for mk3 cabrio i think. it was also fitted to passat etc
vwsystems
Re:help with alarm
« Reply #3 on: 04 July 2004, 17:05 »
how many wires have you got!
i'm not 100% sure but your alarm may have wires like theses
this is normaly the case with most alarms!
red wire - +12v
balck wire - negative / earth
brown wire - negative trigger input ...... like untrasonics or bonnet / door switch.........
yellow wire - negative trigger output when alarm is armed! this switches the untrasonics on........
orange wire - negative trigger output when alarm is sounding.... connects to pager! or internal siren.......
most alarms have wiring like that........
some can have orange or gray wires which connect tothe indicators...... it all depends on what make model it is etc etc......... this may help you.........
i'll have a search on the net and see if i can find anything!
« Last Edit: 04 July 2004, 17:06 by vwsystems »
