Author Topic: high idle problems caused by throttle switches!  (Read 7412 times)
Offline Deefadog
  • Mk2 16V (November 89)
Re:high idle problems caused by throttle switches!
« Reply #10 on: 07 July 2004, 00:09 »
Thanks, how do i set the MFA into diagnostic mode?
Offline Gambit
« Reply #11 on: 07 July 2004, 13:30 »
with the ignition switced off, hold the MFA button in, then with the button still held in turn the ignition on, then off then start the car
always making sure you hold the button in till the car is started
then scroll thru the options on setting 2, there is a digital rev count somewhere there!
Offline Gambit
« Reply #12 on: 07 July 2004, 13:37 »
this link shows all the various settings
MFA Diagnostic Mode
Offline Deefadog
« Reply #13 on: 07 July 2004, 20:51 »
Thanks Gambit, never new that existed :)
Offline Deefadog
« Reply #14 on: 08 July 2004, 23:37 »
Anyone got a list of the readings a 16v golf should Be, the readings on there are for cabs and other models.
Thanks again
Offline Deefadog
« Reply #15 on: 12 July 2004, 12:50 »
Quote
deefadog, 16v idle is between 950-1050rpm
if anything set your MFA into diagnostic mode and it will give you a digital display of the revs's - this is a lot more accurate than the clock
to set your idle
get the car upto running temp
turn engine off
disconnect the red wire coming from the coil (this turns the ISV off)
disconnect the engine breather at the airbox end
start the car
adjust the idle screw till its at 1000rpm
turn the car off again
re-connect the red wire
and thats your idle set
if it wont sit at a steady idle but flucuates up n down by +-50rpm then you need to get the CO level adjusted to 2%
Can you pelase show me a pic of the red wire and coild and which engine breather, is this the one that goes into the front of the engine?
and how do you adjust the CO, any links please
Thanks
Offline Gambit
« Reply #16 on: 15 July 2004, 15:31 »
use this link for settin up your 16v
16v setup
Offline Deefadog
« Reply #17 on: 15 July 2004, 17:04 »
Cheers mate, that's great.  Got everything set up now!
Should my intake vaccum reading be 510?
Thanks again
Offline Gambit
« Reply #18 on: 16 July 2004, 11:08 »
havent got a clue bout the intake vacuum as i've never bothered to check mine. ill give it a go over the weekend and let you know
Offline Deefadog
« Reply #19 on: 16 July 2004, 18:54 »
Thanks mate, have a good weekend!
