Author Topic: MK2 1.8 8v burning water  (Read 2835 times)
Offline weston99
« on: 14 February 2009, 18:56 »
hi guys i have a mk2 golf driver with a 1.8 8v engine with a Pieburg 2e2 carb and its burning water any ideas plus it holds revs at 2500+ thanks.
Offline OakeyDoak16v
Re: MK2 1.8 8v burning water
« Reply #1 on: 15 February 2009, 00:44 »
BURNING water?  :huh:
Offline weston99
« Reply #2 on: 15 February 2009, 02:27 »
i'll try and explain anyway intake manifold there is a hole i dont know if theres ment to be a sensor there or a plug or pipe but water is pising out every time i fill expansion tank up. Thats one thing next is when i start the car it runs up to about 3500+ rpm its blowing white smoke and water is defo coming from the exhaust any thoughts???
« Reply #3 on: 15 February 2009, 10:53 »
are you talking about a water leak on the mounting face of the inlet manifold?  thers an o'ring that seals it.  If not it may have blown a core plug, or are you talking about the main coolant pipe that connects to the carb?  Wherever the leak is coming from this will stop proper coolant flow around the carb and will cause the waxstat to play up, in turn causing the high rpm.  Have a look at my 2e2 faq, once you figure out where the leak is from you need to eiher replae that seal or find another inlet manifold :)
Offline Mrpug
« Reply #4 on: 17 February 2009, 04:05 »
If the white smoke is comming out the tail pipe, that's not a good thing. Is it maybe any loss of power or rough idle. if so I'd look for ahead gasket problem. or if the oil look like chowder or creamer, or if the exaughst smells like coolant (out the tail pipe). Hope it sorts for ya. keep us informed.
Offline weston99
« Reply #5 on: 17 February 2009, 10:27 »
its white smoke it runs fine at 2500+ just dosent drop. the oil is fine. but iam thinking it might be the seal thats on the intake manifold that connects to the head for the coolent? plus the cars been off the road for 3 months. Right the two circles thats where the water is coming from its only one hole though.
« Last Edit: 17 February 2009, 11:30 by weston99 »
« Reply #6 on: 17 February 2009, 12:49 »
those are core plugs that pop if the coolant freezes, you could try to get new ones from VW though I'd just get a known good 2nd hand one if you can.  The coolant channle o'ring is part 32, make sure you ghet a new one of those as well as the inlet gasket, also while its off a new carb flange is a good idea.
Offline weston99
« Reply #7 on: 17 February 2009, 13:55 »
so by getting one of those cause its missing will help coolant circulate? and solve my problem? thanks for the advice rubjonny  :smiley:
« Reply #8 on: 17 February 2009, 14:45 »
possibly yes, a leak like that will prevent the system from pressurising so will allow the coolant to boil, which will introduce air locks, as will the eventual coolant loss resulting in a low coolant level.  Just gotta hope no serious damage has been done!
