Author Topic: Who's sprayed their walnut trim?  (Read 3103 times)
Offline northeast_gti-t
  • "1.8T AGU"
Re: Who's sprayed their walnut trim?
« Reply #10 on: 14 February 2009, 00:29 »
Anyone know how I remove the walnut trim that's on each side of the stereo/heating controls?  The thin bits?
you can do it the easy way ie small flat screwdriver and try to move it upwards but tbh i would remove your side trim (of the centre section) and radio/cd player etc to leave just the cage and then remove that as a unit the side pieces can be pushed up and then pop out not to bad a job  :smiley:
2000 Mkiv GTi 1.8T AGU
Offline bobbarley
  • I'm kind of a big deal...
« Reply #11 on: 14 February 2009, 00:33 »
I wondered if I'd he able to just pop the trims off or not.
  • "1.8T AGU"
« Reply #12 on: 14 February 2009, 01:12 »
possibly but at the bottom of the trim piece it curves round and under :laugh: there isnt much room  to lift as such iirc somebody(although i think not on here)has done it this way tbh i would remove trim etc and try it that way bob :wink:
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« Reply #13 on: 14 February 2009, 18:54 »
looks good mite have to have ago at that where did u get the paint from northeast
  • "1.8T AGU"
« Reply #14 on: 14 February 2009, 19:33 »
cheers mate :afro: the paint was from motorworld its "carplan" colormatch aluminium and i used grey primer couple of coats with the primer to get a base and then 3 coats of aluminium spray and 2 coats of clear laquer( dealers-used the rest up when i brought tin of reflex silver) hth mate
Offline MrTurner
  • Facelift leon cupra
« Reply #15 on: 15 February 2009, 00:33 »
I actually like the standard trim  :lipsrsealed:
Offline Ridg
  • TDI - Soot Happens!
« Reply #16 on: 15 February 2009, 10:04 »
i don't mind the wood trim either, but if you want to change your Knob you really need to match the trim.
mine in reflex silver
Offline Kerrse
« Reply #17 on: 15 February 2009, 10:10 »
I don't mind the standard trim, it doesn't offend me enough to rip it out   :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #18 on: 15 February 2009, 11:37 »
I quite like that, if my imitation alu bits bubble up in the summer (like everyone predicts :wink:) I might spray mine up
  • "1.8T AGU"
« Reply #19 on: 15 February 2009, 14:12 »
a fan of the std trim  :laugh: :grin: think i had mine in a week and it got changed  :smiley: didnt like it much when i went to look at the car but as soon as i found out it could be changed well r32 trim it was  :rolleyes:
