Author Topic: Front Seats moving.......  (Read 950 times)
Offline 993turbo
  • Too many cars, too little time......
« on: 13 February 2009, 13:43 »
The front seats in my G60 are moving ever so slightly side to side...... this is uncomfortable whilst driving...
is the plastic clips in the sliding guides the issue??
If so, I take it this will solve it:
http://cgi.ebay.co.uk/VW-GOLF-MK1-MK2-MK3-GTI-SEAT-CLIP-GUIDE-C66_W0QQitemZ200287186348QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item200287186348&_trksid=p3286.c0.m14&_trkparms=72%3A1689%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
or, any other tips / hints....?
93 Golf VR6 (burgundry) - 93 Golf VR6 (silver) - Ferrari 360 Modena - Porsche 928S2 Strosek - Porsche 928GT
Offline vwade
Re: Front Seats moving.......
« Reply #1 on: 13 February 2009, 13:47 »
yeah they will cure it
Offline 993turbo
« Reply #2 on: 13 February 2009, 14:04 »
cheers, I will ''invest'' in a few of these then :-)
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #3 on: 13 February 2009, 19:01 »
Also look at the front mount as well. There should be a rubber wrap around affair on the mount that the rail slides into. That will also make a difference. It sounds as if the car has had a sketchy existence with the seats been removed and not fitted correctly. Mine was just neglected until I got it as you may have seen from my projects thread.
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 13 February 2009, 19:14 »
I've found the plastic clips actually in the seat rail - they actually slide off the locating tabs in the tracks.  This gives a wonderful 'AAARRRRGHH!' feeling on cornering, where the seat runner is neither located top or bottom - it feels like the seat might just tip over!
When you replace them you should clean out the runners of all the debris in there and give them a spray of white grease to help the seat adjust.  I suspect the runners will be full of grit and fluff and junk, which is why the clips have come off.
Offline 993turbo
« Reply #5 on: 13 February 2009, 23:48 »
yeah, I will do. Does anyone have a pict of the mount?
