Author Topic: Removing bond/mastic/sealer  (Read 1704 times)
Offline Vdubbster
« on: 12 February 2009, 23:54 »
Hello
I need to remove some bond where someone has had a spoiler on a tailgate. Its very thick and difficult to get off
Any suggestions, I have attempted to heat it up but no joy.?
 :smiley:
Offline pedro2682
  • GET IT IN, GET IT OUT, GET IT HOME, GET IT WASHED
Re: Removing bond/mastic/sealer
« Reply #1 on: 13 February 2009, 01:31 »
Sounds nasty. :sad:
Had the same problem, some twit thought it would be a good idea to stick the side trimmings on with black silicone. :angry:
I bought a knife, the ones you can snap a small section off at a time. Pulled it right out, put a little insulating tape around the tip of the blade. Place a little pressure on it to form a bent and then slowly worked my way down it, getting it close and not to hit the paint. Then with a little petrol, work it in to the area affected only leave for 5-10 mins and pick away with your fingers. It would be a good idea to grow ALL your finger nails because you will need them. :shocked:
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 13 February 2009, 09:45 »
try autoglym tar remover! works wonders  :wink:
Offline Vdubbster
« Reply #3 on: 13 February 2009, 12:09 »
cheers guys
