Author Topic: mk1 gti scrap or keep?  (Read 5374 times)
Offline jamadz
Re: mk1 gti scrap or keep?
« Reply #10 on: 15 February 2009, 12:51 »
I've had this issue on a few mk1 golf's 'the car runs just kangaroos once warmed up' - it was the Fuel Rely, when it gets warmed up (it will be hot) the fueling its provided to the engine injectors properly. Replace the Fuel Rely.
Cheers Madone_si
This morning ive gone and bought another fuel pump relay, maybe the one i bought a few months ago was duff,
I have the old style fuse box with the bullet shaped fuses, the fuel pump relay has a new fuse and not the old style.
is there another relay just called fuel relay or did you mean the fuel pump relay?
Offline Madone_si
  • Seattle WA, USA and Middlesex, UK
« Reply #11 on: 15 February 2009, 23:12 »
sorry I meant to say Fuel pump relay.
Full details can be seen on this page regarding fuses and relays - http://www.cabby-info.com/electrical_system.htm (Very useful website as mk1 details are near the same as cabs)
Make sure wiring on the back of the fuse box is ok as well and not burnt. Check the wiring near the fuel pump also.
« Last Edit: 15 February 2009, 23:13 by Madone_si »
Old Skool Mk1 Golf Gli (82), Mk1 US Cab 85 and 83
SOLD - BLACK SOY 92
Offline jamadz
« Reply #12 on: 16 February 2009, 00:05 »
today ive tried a new fuel pump relay, but ive noticed that my relays are a little mixed up, im starting to think i should check the diagram against what the car has, cheers again madone_si
ill be back
Offline mattneck(Beavis)
  • Bristol's Own (DJ) Beavis ;-)
« Reply #13 on: 24 February 2009, 13:25 »
jamadz. try both of these..
Vee W Services
Garage: 0117 966 89 59
Parts: 0117 941 86 41, or 42 (2 lines) if anybody in the aprts end of thing is going to know anything about it or be able to advise, it will be Dan..
HTH
Sig Removed. No Longer Applicable. New Sig? Nah. Not Yet..
Quote
Sharpo says: (16:57:39)
to be honest i dont doubt that half ggti users have a shortcut on their desktop for sharpie's last posts
Offline danny_p
« Reply #14 on: 24 February 2009, 16:51 »
well  i know where there is a spare ABF and a loom
all the VW's have gone bar 1.
« Reply #15 on: 24 February 2009, 17:20 »
that cabby link is no good to you, thats only valid for the later blade fuse type fusebox, the ceramic layout is different.  I have the pinouts on the rear of the ceramic fusebox in my faq but i have yet to sort out the fuse/relay layout.  Your symptoms wont be caused by relay missmatching anyway, if they were in the wrong spot it wouldnt run at all!
MK1 kangarooing can be caused by rust in the fuel system, common fault as they get older as the fuel fillter necks are steel, as are the fuel tanks.  Have a look at the filler neck, if you see any rust on it get a new one fitted as soon as you can, then use the magnet on a string trick to fish out any rusticles floating in the tank.  Lift up the rear seat, remove the metal cap and then take out the fuel level sender, chuck a magnet on a string in the hole. drive it for a week then fish it out, clean off any rust then chuck it back in.  Repeat till it comes out clean.
Once thats sorted, pop off the L shaped hose between the tank and fuel pump, get ready to block the tank outlet or it'll drain all the fuel out!  Then shine a torch down the fuel pump inlet, some have an inline basket filter. If fitted it will probably be filled with crud, clean that out & refit.  Last of all, chuck a new fuel filter on there.
If all that doesn't help you might have rust in the injection system, which for k-jet is usually pretty terminal :(
