Author Topic: 195/60/15 on Golf2 1986  (Read 1992 times)
Offline mhitrov
« on: 12 February 2009, 00:08 »
Hi,
Is it real to put 195/60/15 allow wheels on Golf 2 1.8 Syncro 1986?
Thanks!
Offline danny_p
Re: 195/60/15 on Golf2 1986
« Reply #1 on: 12 February 2009, 01:14 »
195/50/15  is the norm    but 195/60/15 will be ok
its the offset and center bore that are more inportant
« Last Edit: 12 February 2009, 01:24 by danny_p »
all the VW's have gone bar 1.
Offline Village Idiots
« Reply #2 on: 12 February 2009, 08:42 »
These will give a slightly larger rolling diameter which will mean speedo will read slightly slow and performance will not be quite as snappy.
But probably not that much that you would notice.
Offline sidecarphil
« Reply #3 on: 12 February 2009, 14:41 »
i got 205/50/15 on mine and acording to my tom tom tw*tnav my real speed is the same as the speedo
Offline mhitrov
« Reply #4 on: 12 February 2009, 15:51 »
What about 185/65/15 for 6.5''x15'' rim on Golf 2?
So, actualy, can i set 195/60/15 without problems? Does anybody have a picture of 195/60/15 on Golf2?
Thanks!
Offline sidecarphil
« Reply #5 on: 12 February 2009, 17:21 »
Thanks!
it's not 6.5" it is 65% of 185mm  :cool: :cool:
Offline danny_p
« Reply #6 on: 12 February 2009, 17:40 »
why want to run strange tyer sizes anyway ?
Offline JC
  • Back in the North.
« Reply #7 on: 12 February 2009, 17:51 »
work out the difference yasen
http://www.tyresave.co.uk/tyresize.html
 :wink:
Offline twistedblack69
  • Proud mk2 user and abuser
« Reply #8 on: 12 February 2009, 21:27 »
So...on a 195/50/15, the 50 means "50% of 195", 195 being the tread width?? I'm a tyre noob :( also what's offset and centre bore??
Offline Dolly
« Reply #9 on: 14 February 2009, 19:02 »
centre bore is the diametre of the flange on the hub, the actuall part the wheels fit snug agaisnt. 57.1mm
Offset is figured out by measuring where the mounting point of the alloy sits in relation to the inner edge of the wheel?
so if the offset is Zero where it mounts will be where the inner edge of the alloy is? making the rest of the wheel stick outwards?
...*waits to be corrected*
