Author Topic: PB - EV Swap  (Read 735 times)
Offline mercedeslimos
PB - EV Swap
« on: 11 February 2009, 13:42 »
i have my mk2...
the digifant PB 1.8 is away for a rebuild (v. expensive as going uprated.) i have a k-jetronic spec 1.8 EV engine, will this work with all the digifant injection or will i need to change the head?
Re: PB - EV Swap
« Reply #1 on: 12 February 2009, 11:27 »
yep, just unscrew the k-jet injector inserts and fit the digifant ones, there may be a random vac pipe between 3 & 4, block that off.  then its just sensor/flange differences, unbolt the pb bits and bolt em to the ev, but using new plastic flanges :)
