Golf mk1
Heater pipe help required.
Topic: Heater pipe help required. (Read 1490 times)
dan7
85 T25 camper, 90 Mk2 16v, 90 Caddy
10 February 2009, 19:00 »
I fitted a 1.6 8v carb engine into my mk1 Clipper, from a mk2 Driver a while back. After getting through most of the issues, I have one I can't sort. The metal coolant pipe that comes out of the water pump and goes right up to the heater matrix, is too big a diameter to go into the rubber hose with the valve for the heater on it. What can I do to remedy this?
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Heater pipe help required.
11 February 2009, 11:08 »
need to replace the 1.6 pipe with one off a MK1 1.5 lump (or any MK1 based carb lump, scirocco ones etc), you also need the side flange with the extra pipe connection and the short pipe to go with it.
dan7
12 February 2009, 16:21 »
Thanks Jon, knew you'd help out!!!!
Golf mk1
