Author Topic: can i??  (Read 2150 times)
Offline jonny T
can i??
« on: 01 July 2004, 18:54 »
i have got a 1.6 driver mk2 and it's got the dials in for the oil pressure and temp. any way i can wire these up? or do they only work on gti's?
Veedubgt18v
Re:can i??
« Reply #1 on: 01 July 2004, 19:08 »
which one do you mean? are they like this
http://homepage.ntlworld.com/john.combes2/Vdo.htm
Offline jonny T
Re:can i??
« Reply #2 on: 01 July 2004, 22:53 »
yeah they are. can i fit them to my car?
Mixologist
Re:can i??
« Reply #3 on: 01 July 2004, 23:19 »
They should plug straight in, the senders are the same all round on the mk2 (ithink) or take the senders form the car you got the gauges from and they should fit straight in to the old housing of the sensors/sender
Veedubgt18v
Re:can i??
« Reply #4 on: 02 July 2004, 00:07 »
you may have to get the oil filter mount off a gti but looka t it and see if you have a blaking plate or a sender in the two holes on top of the oil filter. send me pics if you can and i will look for you
john.combes2@ntlworld.com
Re:can i??
« Reply #5 on: 02 July 2004, 09:04 »
The oil filter bracket on the Driver doesn't have a holes for the oild temp sensor, you'll need to find somewhere else to mount one.  I've heard that you can get a replacement sump nut and mount one there, but sounds like a bodge to me!
I'm going down the scrappers at the weekend to grab a filter housing and sender off a GTI, fits nicely on the 1.6!  If you manage to find a 16v they have 2 senders so you can do both pressure and temp!
Veedubgt18v
Re:can i??
« Reply #6 on: 02 July 2004, 22:06 »
this is on the 16v and the 8v, there are two senders one drives the oil temp on the mfa and the other is part of the low oil pressure warning system. so you can get the filter mount housing off the 8 or 16 v
Veedubgt18v
Re:can i??
« Reply #7 on: 02 July 2004, 22:12 »
you will need the audi twin pole sender to run the pressure gauge cos the golf one isnt strong enough. see my site for more info
