Author Topic: Turbo Cooling Down  (Read 5479 times)
Offline pazz
Turbo Cooling Down
« on: 09 February 2009, 20:20 »
I'm curious to know if anyone allows the turbo to cool down before turning ignition off etc either by letting it tickover for a while or just easing off the throttle when nearing their destination.
I've had a few Jap motors in the past which always needed the above TLC to save gasket's going etc. However I've heard (what only can be described as a rumour) that VAG motors are able to continue pumping oil round after the ignition has been turned off. Therefore removing the need to let it cool down on tickover etc.
I'm very interested in hearing if anyone has any constructive answers to the above. I can imagine that I wont ever really run into any problems from not following the above MYSELF, but I may well save someone else the hassle later on (car hasnt done enough miles yet).
Offline matthewsimone
Re: Turbo Cooling Down
« Reply #1 on: 15 February 2009, 10:33 »
hi mate ive been wandering this myself but no one seems to no for certain but from my past experience of owning series 1 rs turbos and what friends have said withe there scoobys etc i just give mine 30 seconds ish before turning off just to be on the safe side as i dont intend on buying a new turbo unit whilst owning my gti, my missus moans like mad at me everytime we get to our destination and then she has to wait in the car for a minute whilst turbo winds/cools down but oh well ey lol  :laugh:
Offline Max GTI
« Reply #2 on: 18 February 2009, 16:05 »
Hello pazz
When I got my car remapped by R-Tech I asked the guy if I needed to do anything because of the remap and he said if you have been putting your foot down then leave it 20 - 30 seconds to cool down/stop spooling. But if its normal driving I wouldnt think so but I do it anyway.
25th Anniversary
No. 1117
Offline ub7rm
« Reply #3 on: 18 February 2009, 19:07 »
AFAIK there is an after run coolant pump but there isn't such an arrangement for the oil, so best to follow the above advice and let it tick over if you've been giving it the beans just before parking up.
2020 BMW 128ti
2017 Golf GTD Estate
Offline Rhyso
« Reply #4 on: 18 February 2009, 19:08 »
and ensure that the last half a mile home is nice and gentle  :smiley:
Offline Teutonic_Tamer
« Reply #5 on: 19 February 2009, 11:43 »
I allways do, and I also let it warm up properly too.  As Rhyso stated, you should really be taking it very easy for the last half mile or so - and by taking it easy, be in the highest posible gear, using the lowest possible revs, and very light throttle openings.  You can still cruise along at 60mph (where the law permits!  :tongue:) - but just keep the car in 6th gear, and never use more than half throttle.
Oh, and never, EVER 'blip' the throttle before turning the engine off.
Nope, as ub7rm states, the GTI is only able to reverse pump the engine coolant after the engine is turned off.  But this should NOT be used as a substitute for proper turbo cool down.  Whilst the coolant is being pumped around, it continues to absorb a continued build up of heat from the engine (heat soak), but there is actually no air flow through the radiators, so it isnt actually being cooled (unless it is close to boiling, but then the big cooling fans will be running).
It is best to think of this after-run coolant pump as a 'life-jacket'.  You wouldn't go on a channel ferry, and expect it to capsize, but think you will be perfectly fine because you have a life jacket!
Trouble is, turbos will generally take quite a lot of 'mildly poor abuse' before going pete tong.  But weather they last 5k miles or 50k miles, they are still expensive to replace!
I feel like a homo
Offline pazz
« Reply #6 on: 21 February 2009, 23:34 »
Frankly you'd be stupid to give any engine (even more so a turbocharged one) considerable throttle from cold. The oil will be cold and have the associated viscosity resulting in low oil pressure = starving the block and turbo from fresh oil.
Hmm coolant only, well does anyone know if the KKK K04 found on ED30's is water cooled??
The above would still be useful in stoping the turbocharger overheating. As quoted from garrett website:
Quote
To minimize the effects of heat soak-back, water-cooled center housings were introduced. These use coolant from the engine to act as a heat sink after engine shutdown, preventing the oil from coking. The water lines utilize a thermal siphon effect to reduce the peak heat soak-back temperature after key-off.
In summary, I think I'll carry on with my previous ways and take it steady when approaching my destination etc. "It's the least I can do for my ED30!"
Offline pazz
« Reply #7 on: 21 February 2009, 23:43 »
If anyone is intereted in the link to the website I mentioned above, I cannot recommend it enough for turbo-tech related info. Knowledge from the masters that are Garrett. They explain everything from the basics of classification of size on a turbocharger (trim's etc) all the way through to compressor graphs. Its really not for the faint hearted. An active interest in maths and physics will help!
Their basic guide: http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech101.html.
Only thing they miss out on (or so I remember) is the use of "vaine's" on turbochargers - which VAG use quite a bit I believe.
Offline Schuey
« Reply #8 on: 10 March 2009, 21:27 »
Does the same apply to superchargers??
« Reply #9 on: 12 March 2009, 15:29 »
Actually, when the oil is cold, you can actually get higher pressures than when the oil is hot.  But sadly, the ability of an oil to 'lubricate' has very little to do with actual oil 'pressure' - which explains why oil pressure guages are no longer fitted to cars.
Yup, the K03 and K04 share identical oil and coolant flows.
Quote
I don't dispute what Garrett say - but water cooling is NOT the absolute answer.  Water cooling a turbo with a reverse flow afterrun coolant pump is just similar to lifejackets on a cross chanel ferry - you don't rely on the lifejacket to get your 20 cases of Stella and 400 Marlboro Lights back from Calais, but if the boat capsizes and sinks, then even with the life jacket, you will still get wet, but probably wont die!  And what Garrett fail to mention is that any afterrun cooling will also suck any heat soak build up from the engine block and head, and merrily send that to the turbo bearings too.
Turbo watercooling is NOT to be relied upon.  Just use proper cool-down periods for maximum turbo life, and just let the water cooling act as a low key safety net.
I feel like a homo
