Author Topic: Ravens mk2 48hour surgery...  (Read 2516 times)
Offline sidecarphil
Re: Ravens mk2 48hour surgery...
« Reply #10 on: 10 February 2009, 14:46 »
landrover garages (i work for a dutch one)
but they aint cheap
and you have to file one of the little pins off it as they are offset pin type
but mine are perfect front and rear :)
i'll try get a part number for you tommorrow   :wink: :wink:
thank you  :smiley:
Dan
part number from landrover is XZQ500090 and the cost is €14.34 (please note that is euros ) :grin:
Offline TheRaven
  • "I am female, I think the boobs are a giveaway..."
« Reply #11 on: 10 February 2009, 21:54 »
Cant say how thankful I am to Yellow gti for helping me to do this! I learnt a lot along the way and rescued my beloved car! She may only be a 13 but I love her!!!!!!!  :laugh:
Professional Freelance Equestrian Photographer
www.ravenphotography.co.uk
www.ravenphotography.uk
Offline Dan34
  • VTEC Powerzzzz
« Reply #12 on: 10 February 2009, 22:01 »
but they aint cheap
thank you  :smiley:
Dan
cheers mate will look into that  :smiley:
Dan
Offline daniel-1986
« Reply #13 on: 11 February 2009, 09:34 »
are 1.3 headgaskets hard to change as mine is leaking oil above the alternator and will need to be done eventually
Offline TheRaven
« Reply #14 on: 11 February 2009, 12:54 »
It actually wasnt that hard! It only took us 2 days because we ran out of daylight + it had to be skimmed 5 times!
Taking it apart + putting it back together again was pretty ok! Its a simple engine!
jamrock
« Reply #15 on: 11 February 2009, 15:37 »
Quote from: daniel-1986 on Today at 09:34
are 1.3 headgaskets hard to change as mine is leaking oil above the alternator and will need to be done eventually.
i did the head gasket on my 1.3. was not hard at all, easier then ravens as mine did not need skimming. i had the same problem as u have described. i think you should buy a genuine VW rocker cover gasket as i found other ones to be rubbish. that solved the oil leaking from the corners.
