Author Topic: sorry - springs question.  (Read 1674 times)
Offline edpryce
« on: 08 February 2009, 15:24 »
I have used the search but still am a little unclear, I am trying to lower my car on a budget. (mk2 1984 8v gti). Car has done 80k, on what I believe are the original shocks.
Seen some new Jamex springs (40mm) for sale £30, will I also need to change my shocks or can i use the existing ones? and if I dont, how long will my spine last running standard shocks?
Cheers in advance, lets keep this thread short and sweet for everyones sake.
Ed
Offline edpryce
Re: sorry - springs question.
« Reply #1 on: 08 February 2009, 18:24 »
come on 20 views someone must know????
Offline Ben Lessani
« Reply #2 on: 08 February 2009, 18:32 »
Obviously on a 25 year old car its recommended to replace the shocks if you are replacing the springs, Boge gas from GSF come recommended from most as a budget alternative.
Offline danny_p
« Reply #3 on: 08 February 2009, 18:41 »
std shocks  can manage -40 mm  just  if there in good health and the bumpstops are very good.    worn bumpstops and shocks will last about a week*
*depending how you drive and stiffness of springs ect
all the VW's have gone bar 1.
Offline nealey
« Reply #4 on: 08 February 2009, 19:10 »
I would seroiusly change the shocks as well, buy the springs now and the shocks later and fit them at the same time if you are on a budget
Offline edpryce
« Reply #5 on: 08 February 2009, 20:04 »
Cheers, I guess I will need to start looking at shock prices. Novice - are bump stops included with shocks or are they an extra?
Offline nealey
« Reply #6 on: 08 February 2009, 21:06 »
bump stops are extra, you will also probably need to renew the front top mounts
Offline edpryce
« Reply #7 on: 08 February 2009, 21:16 »
starting to add up, looking like those hotuning coilovers might be a cheaper option?
Offline OakeyDoak16v
« Reply #8 on: 08 February 2009, 21:27 »
If your worried about your spine i think you need to consider a shock and spring combo. This is what i am about to do for similar reasons. Can't you wait and save the cash instead of spunking it on a cheap compromise? :smiley:
Offline cняis
« Reply #9 on: 08 February 2009, 23:31 »
go for new shocks and springs, no point relying on crappy old shocks to take the strain.
also new top mounts are a must, the bearings are liable to seize resulting in VERY notchy and stiff steering (from experience) and take bugger all to change once the shocks are off. they cost about £20-£25 for a pair
you only want to do the job once  :wink:
