Golf mk2
heater squeel when turning left..
Topic: heater squeel when turning left.. (Read 1143 times)
jamie_pyrite
08 February 2009, 00:18 »
Hi all, just a quick question. On my 1990 1.6TX non-PAS Jetta, when I turn left with the fan on any setting 1 to 3, it squeels! Why's this and is it sorted? It's doing my head in!!
And why is it only doing it when turning left?
Cheers!
My Photography
OakeyDoak16v
Re: heater squeel when turning left..
08 February 2009, 01:08 »
Bearings in fan buggred? Buy repalcement fan. Well cheap and easy to replace. Or try WD40 for a quick fix?
jamie_pyrite
08 February 2009, 01:44 »
How do I get into the fans?
My Photography
sidecarphil
08 February 2009, 08:05 »
under the passinger side of the dash
there is a cover , pull it off and there is the motor
or if you remove the scuttle panel cover (under the bonnet)
and spray WD40 into it with the fan on 1 or 2
thats what i did to mine yesterday
dan7
85 T25 camper, 90 Mk2 16v, 90 Caddy
08 February 2009, 09:47 »
Ditto! Mine sounds like a cat being strangled!!! How can I get the motor out? Got good access to it, undone a black screw knob fastener, but still won't release. Any ideas??? Oh. and done a search already btw!!
nealey
08 February 2009, 19:22 »
You have to twist the fan motor as its on a clip then it comes down
Golf mk2
