Author Topic: Montreal 2 Questions  (Read 2291 times)
Offline saalro
« on: 06 February 2009, 21:28 »
What offset are the Montreal 2's GTI Mark 4 Wheels, i saw this:
6.5x16 ET42 5/100 Montreal II
But i heard they where ET38? Also my tyres are 205 55 16, and 205 MM is 8.07086614 inches? And them stats above say they are 6.5? Am i looking at this the wrong way? The tyre can't be .75 inch widder over the two sides of the alloy can it?
Also what does the 5/100 mean.
Thanksss.
Offline JC
  • Back in the North.
Re: Montreal 2 Questions
« Reply #1 on: 06 February 2009, 21:32 »
5x100 is the stud pattern  5 bolts - not sure on the 100 bit - but i wil return  :wink:
ta dar
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=92
 :wink:
« Last Edit: 06 February 2009, 21:33 by chuff »
Offline saalro
« Reply #2 on: 06 February 2009, 21:39 »
Thanks, anyone got answer for the other questions!?
Offline saalro
« Reply #3 on: 10 February 2009, 13:02 »
BUMP
« Reply #4 on: 11 February 2009, 08:55 »
Thanksss.
5x100 = stud pattern
et42 = offset (the higher the number the further into the wheel arch it will be)
6.5 x 16= is the size and yes 205/55/16 will be fine.
Offline saalro
« Reply #5 on: 11 February 2009, 13:15 »
Thanks for the help but :rolleyes: i'm aware of what all the stats mean apart from the stud pattern, but i know that now lol, i just thought the offset for Moreal 2's weren't ET42, i thought they were sligtly lower, is ET42 correct then?
And i assumed that because the tyre size is about 8 inch wide for this specific wheel and the alloy itself is only 6.5 inches wide, i thought the stats might be wrong. I'm really just wanting an answer to whether these figures i have are correct?!
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #6 on: 16 February 2009, 19:59 »
i had my montreals off couple of weeks ago and the offset is et42
2000 Mkiv GTi 1.8T AGU
Offline saalro
« Reply #7 on: 16 February 2009, 21:26 »
Thanks!
  • "1.8T AGU"
« Reply #8 on: 16 February 2009, 21:28 »
no problem glad to help  :wink:
