Author Topic: What you need to know about getting new alloys???  (Read 1672 times)
Offline saalro
« on: 06 February 2009, 18:10 »
Okay so i'm curious, i was looking at getting 18's, am i right in thinking the right tyre wall size to get would be 40mm so that you do not loose the circumference of the wheel and mess up the speedo reading?
I was looking at some 18's and the site recommends 225 40 18 for this specific wheel, but then it also says that you can run 215 35 18, but how would that work, surely the width has got to be exact and not vary?
Thanks
« Last Edit: 06 February 2009, 20:28 by saalro »
Offline Jimp
Re: What you need to know about getting new alloys???
« Reply #1 on: 06 February 2009, 21:03 »
I think the 215/35/18 is if you want a stretched tire look? I'm not sure though.
Not low enough mk5
Not on the road enough mk3
Offline saalro
« Reply #2 on: 06 February 2009, 21:21 »
What is a stretched look, the Euro style look where tyre arches a bit?
« Reply #3 on: 10 February 2009, 09:07 »
What car are you fitting them to.
Offline saalro
« Reply #4 on: 10 February 2009, 13:03 »
I'll be fitting them too a Golf Mark 4 GTI 150BHP.
« Reply #5 on: 11 February 2009, 08:51 »
I would run 225/40/18's anything else will look to small.
Offline saalro
« Reply #6 on: 11 February 2009, 13:09 »
Is there a certain percentage you can go over and below for the sidewalls untill the speedo becomes a problem?
