Author Topic: 7.25J rims on a lowered MkII  (Read 893 times)
Offline JC
  • Back in the North.
« on: 05 February 2009, 18:55 »
I have fallen in love with a set of rims, but they are 7.25J on a 15 inch with an ET of 35 :shocked:
whats the largest size peeps have fitted on a lowered MkII WITHOUT arch rollage  :undecided:
Offline Benrevs
Re: 7.25J rims on a lowered MkII
« Reply #1 on: 05 February 2009, 19:28 »
I have the same on mine Chuff, mim 1000's iirc. Same offset too, the car was lowered 60-70mm and they only scrubbed at speed on full lock... nothing a bit of raisage wouldnt fix! Ben
Offline JC
« Reply #2 on: 05 February 2009, 19:31 »
more worried about the rear  :huh:
Offline Benrevs
« Reply #3 on: 05 February 2009, 19:33 »
Yea no probs with the rear on mine, slightly stretched tyres help but they will be stretched a touch anyway due to the width.
« Reply #4 on: 06 February 2009, 08:43 »
ET of 35 is fine, you have an extra 1/2" there but it should still be ok.  I have gone as low as ET18 at the back with no rubbing, but that was with falken ze512s which have a stretched look tyre profile so give you a bit extra room (195/50)
Up front I had ET24s and they started to catch when the camber was reset, but hammer work to the metal lip and the plastic lip was chopped out, now I have ET13s and they are fine.
