Author Topic: Help, no brake lights!  (Read 3398 times)
Offline Mirage-
« on: 30 June 2004, 09:47 »
Guys a friend following me the other day noticed that I had no brake lights.  I've checked the fuse and nothing wrong there, checked the bulbs and nothing wrong there.  Only thing I could think of was the switch? but need somebody to tell me what I'm looking for so that I can fix it.
Any help greatly appreciated.
Regards
Ian
Offline gibby
Re:Help, no brake lights!
« Reply #1 on: 30 June 2004, 10:08 »
Now then mirage, hope you are well matey, still need to sort out a meet sometime. Anyway, if fuse and bulbs are ok then normally there is a plug just above the brake pedal that makes the contact to turn on the lights when the pedal is pressed, this can sometimes work loose, check that out.  :)
......now officially dubless.
golfvr6
« Reply #2 on: 30 June 2004, 15:56 »
The brake light switch on the brake pedal is a common failure.
New switch costs no more than a tenner.
Offline JMallows
« Reply #3 on: 30 June 2004, 16:17 »
Could also be the connections on the bulb holder, mine was a bit intermittent on one side, nothing to stop it being both sides??!
A clever person solves a problem. A wise person avoids it.
Offline Martz
« Reply #4 on: 30 June 2004, 21:22 »
I agree with golfVR6. I had to replace 2 on my A3. German & Swedish do them for a ?5.
Takes about 5 mins to do.
Good luck.
golfvr6
« Reply #5 on: 30 June 2004, 23:46 »
Don't buy it from German and Swedish, thats probably why you had to do it twice, vw costs a small fraction more.
If both sides have gone and the bullbs and fuse are ok, chances are it will be the switch itself.
Offline Mirage-
« Reply #6 on: 01 July 2004, 10:15 »
Thanks guys it was the switch but me being me didn't bother taking it out, just hit it with contact cleaner and give it a bit of play to loosen it up again.
I'm not lazy, I don't mind doing jobs once I start I just have motivational issues.  ;D
Ian
Offline Martz
« Reply #7 on: 01 July 2004, 10:21 »
It was VAG branded so would make no difference. ;)
Offline gibby
« Reply #8 on: 01 July 2004, 10:34 »
.....and gibby  ???
Offline Martz
« Reply #9 on: 01 July 2004, 10:44 »
Sorry Gibby, I agree with you too mate! :P
