Author Topic: Golf 8v Tyre size and pressures  (Read 5309 times)
Offline blu16v
  • 1987 Mk2 16v + 1996 Mk3 8v
« on: 29 June 2004, 21:02 »
I recently bought a second golf, a '96 Mk3 2.0 8v.   It is running 205x50x15 tyres. What is the recommended pressure compromise for best ride and handling?
The tyres are currently running 30psi all round, this seems a bit hard on the rear as it is quite hard over the bumps, but this could be the suspension.
What is the correct tyre size and will these tyre sizes affect the speedo reading?
Offline 8vgti
Re:Golf 8v Tyre size and pressures
« Reply #1 on: 30 June 2004, 13:34 »
They are the standard tyre size for your motor...I think prior to 1995 the tyres were 195s. Pressures should be 30psi for the fronts and 28 for the rears. Thats what it says on the fuel filler flap and seems to work ok for me.
Offline blu16v
« Reply #2 on: 30 June 2004, 17:40 »
Thanks for the reply, I have already dropped the rears by 2psi, so looks like i accidentally got it right.
Offline Grovit
« Reply #3 on: 18 July 2004, 16:43 »
hmmm, I was going to ask this question as my Gti was fitted with (by the previous owner) 205/50/15 on the front axle and 195/50/15 on the rear axle.
THe Golf is a MkIII Gti 8v on an L reg - 1993
Chris
I went to a seafood disco last week...and pulled a muscle.
Offline adyh
« Reply #4 on: 19 July 2004, 10:19 »
Have you checked all of the tires ?
Its could be that the car has had a smack and some previous owner has bought a wheel from the scappers.
The tires should be the same width all the way round the car .
nogama3
« Reply #5 on: 26 July 2004, 12:25 »
are the rear tyres newer than the front, t may be that the previous wner replaced the rears with 195's as they are cheaper than 205's.
nogama3
« Reply #6 on: 26 July 2004, 12:25 »
