Author Topic: Expansion Tank  (Read 1001 times)
Offline Winso
Expansion Tank
« on: 04 February 2009, 09:34 »
Expansion tanks from GSF.... Am I right in thinking the low coolant level sensor is 'built in' to the tank? Just want to double check!
Re: Expansion Tank
« Reply #1 on: 04 February 2009, 10:00 »
post 90 I assume, then yes. pre-90 its screwed in
Offline mattkh
Re: Expansion Tank
« Reply #2 on: 04 February 2009, 22:13 »
Hi
I had a problem with the electrical connector on the bottle I bt from GSF.
Check that the electrical connector plugs in correctly before paying.
Offline Eddie
Re: Expansion Tank
« Reply #3 on: 06 February 2009, 23:42 »
I've had two epansion tanks from GSF for my 1990 16v. The first one was an exact replica of the original VAG one i was replacing.
Within three weeks it started leaking at the seam at the circumference of the tank, back it went and i got an after market one that was almost transparent. Not had a problem since. However the electrical connection for the level sensor is easy to miss align with the connection on the car side.
I recommend checking that the two contacts in the expansion tank are straight and level before connecting the plug.
