Author Topic: brakes  (Read 2557 times)
Offline bully85
brakes
« on: 03 February 2009, 22:22 »
brakes of a mk4 golf 1.8t standard brakes fit a mk1?
Offline dan_b998
Re: brakes
« Reply #1 on: 10 March 2009, 23:41 »
i beleive the mk4 have 5 studs the mk1 has 4 studs m8 so unlesss the mk4 has 4 studs ur outa luck there
where as if they do have 4 studs
ask someone like rubjonny hes really good when it comes to wht parts fit an what don't
Re: brakes
« Reply #2 on: 11 March 2009, 08:37 »
not without serious modification, carrier mountings are different, disc offset all wrong etc.  Biggest option you can fit easily is a set of 280 4 stud calipers n carriers using conversion brackets from the caddy forum.
Re: brakes
« Reply #3 on: 12 March 2009, 20:52 »
Another option is the late mk 256mm setup which easy enough to fit.
Re: brakes
« Reply #4 on: 13 March 2009, 11:16 »
late mk what?  :grin:
scirooc 16v and early audi 80 carriers are what you need for a bolt on 256 upgrade on a MK1, the bolt spacing on the carriers must be 75mm (MK2/3 are 95mm)
Re: brakes
« Reply #5 on: 13 March 2009, 13:45 »
Yes was thinking Audi carriers.
