Author Topic: 3a bubble block gearbox options?  (Read 1835 times)
Offline Dr Gonzo
« on: 02 February 2009, 20:48 »
Hi guys, i've recently got myself an Audi 3a 'bubble block' complete engine, of which i plan to stick the bottom end into my 1.8 clipper.  I'm just wondering what people's opinions are on which gearbox would be best to go with.  My gearbox in the clipper is working fine, but have read that a mk3 diesel gearbox could be the way to go?  Cheers.
Re: 3a bubble block gearbox options?
« Reply #1 on: 03 February 2009, 09:56 »
a diesel box would have really long ratios so probably would annoy you.  it isnt any stronger either so not worth it from that point of view.  if your old box is in good condition use that, fit a nice new 210mm clutch and your old flywheel and away you go.
Oh this assumes your old clutch was a 210, if it was a 190 or 200 one then as above but you want a 210mm flywheel from a MK1/2 GTI or scirocco.  Some MK3 ones fit but make sure it has 2 dowel pins, the later ones have just the 1 and are heavier, plus they require a different clutch that wont fit your box.
Offline Dr Gonzo
« Reply #2 on: 03 February 2009, 18:35 »
Thanks Jon, good advice :smiley:
« Reply #3 on: 04 February 2009, 08:26 »
no problem, now all you gotta do is build it :P
