Author Topic: Mk3 Soundsystem  (Read 13821 times)
Offline LazyLunatic
  • MK3 20VT Project
Re: Mk3 Soundsystem
« Reply #20 on: 10 February 2009, 19:07 »
now i know people disagree with the 6x9 thing, but a sub - now you need one of them! tbh i want more bass lol!
like someone said already though, a decent set of components, say type r with crossovers and tweeters and sound deadening, means you can turn bass up without distortion or much vibration.
LL ;)
Offline Len
Re: Mk3 Soundsystem
« Reply #21 on: 10 February 2009, 20:45 »
My sub and amp both feed power from same as H/U.
Power caps are crap anyway!
www.sas.org.uk
www.the-ace.org.uk
Offline LazyLunatic
  • MK3 20VT Project
Re: Mk3 Soundsystem
« Reply #22 on: 10 February 2009, 22:10 »
so i heard, im was thinking about getting bigger amp and more powerful subs, but all the lights dim enough already lol!
mmmmmm bigger alternator....................
Offline eightyeightmph
Re: Mk3 Soundsystem
« Reply #23 on: 11 February 2009, 00:22 »
Bigger engine! :lipsrsealed:
2016 GOLF GTD
Offline LazyLunatic
  • MK3 20VT Project
Re: Mk3 Soundsystem
« Reply #24 on: 11 February 2009, 00:51 »
sorting that out atm, OK!!!!! :D
Offline Len
Re: Mk3 Soundsystem
« Reply #25 on: 11 February 2009, 15:40 »
If you get power loses like that then you should probably run a direct cable to the battery to the amps.
And also get your alternator checked.
www.sas.org.uk
www.the-ace.org.uk
Offline tommk3cab
Re: Mk3 Soundsystem
« Reply #26 on: 12 February 2009, 13:44 »
are you saying your amp power cable goes to the permanent live for your HU?
Is there any other way?
Offline Len
Re: Mk3 Soundsystem
« Reply #27 on: 12 February 2009, 15:20 »
I believe so! Billy wired it up so not sure! Has worked fine for 3 years or so, so why change it?
As for your second point as above and if it aint broke why fix it?
www.sas.org.uk
www.the-ace.org.uk
Offline tshirt2k
  • Been there...Done that...
Re: Mk3 Soundsystem
« Reply #28 on: 13 February 2009, 09:58 »
I can't believe what i'm reading  :laugh:. 6x9 are a Big no no in car audio circles. When you get a decent set of components and i mean decent and run off a powerful amp. You dont even a sub. Personally i couldn't live without sub bass in my sytem but with 6x9's you drag the sound backwards. Eg If you were at a concert, would you sit at the back and turn you back on the band?? :huh:
If the system is setup correct, then the sub is balanced with the rest of the sound.
If your lights are dimming then you will need to sort out your cabling. Add some proper sized power and earth cable. No point adding alternators and batteries if your supply cables cant supply any more current. Sounds like its a fire waiting to happen :shocked:
I have two different systems in my cars. 1 has expensive components and quality 10" sub in a sealed enclosure all runing off a single rockford Amp. The sound is very clean and clear.
The other is a two JBL amp system. One amp is 100w/ channel running some average components (which i am looking to change). The other amp is 600w RMS running a 12" sub in a ported box. This system is alot louder but not as clean because the components are cheaper. And not a rear speaker in site and def no 6x9's. This car has 0 gauge cables for battery earth and power for amps and the lights never dim even wen cranked up.
Mk3 ABF 16VT Megasquirt V3
Offline Len
Re: Mk3 Soundsystem
« Reply #29 on: 13 February 2009, 11:58 »
As said right at the beginning - each to his own!
www.sas.org.uk
www.the-ace.org.uk
