Author Topic: Fixing Brakes Advice  (Read 2051 times)
Offline Grazy
« on: 02 February 2009, 10:56 »
Hi people , need to replace brakelines on my 8v Gti 91 , is there any special tools or advice needed to do this ?  I have a dry lock up to do work in and have from wednesday onwards to do it so any advice gratefull recieved ,
   I have Bently manual and will be reading this lots too  :rolleyes:
Offline pro-biotic
Re: Fixing Brakes Advice
« Reply #1 on: 02 February 2009, 11:20 »
ines as in metal pipes aswell as flexis?
id get myself :-
a flairing kit
 a load of pipe
the spring clip pipe to flexi holders
before starting might be an idea to check if all your bleed nipples are free
Offline Oilburner
« Reply #2 on: 02 February 2009, 11:39 »
id get myself :-
a flairing kit
 a load of pipe
Oh yes; deffinately check the bleed nipples are free and not seized. Snapped bleed nipples =  :angry: :angry: :angry: :angry:
I did the lines on my old v6 barge and 2 snapped of trying to 'gently' ease them open....  :angry:
Do you think i was p*ssed off?? :laugh:
1987 - MkII Golf GTI 16v
2005 - MkIV Golf GTTDI 140
Offline pro-biotic
« Reply #3 on: 02 February 2009, 11:42 »
11mm flair nut spanner too - better than rounding off things
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #4 on: 02 February 2009, 13:15 »
when undoing the bleed nipples use a ring spanner not the flair nut spanner.
Offline golfnut8v
« Reply #5 on: 02 February 2009, 14:45 »
get into all the bleed nipples and other connections with a wire brush and wd......make sure you polish all shiney clean before you try  any movement at all..........move all nipples slowly one/two turns forward and then turn back to free all sh1t off threads...do not rush this if you do it will end in tears.....
Offline Grazy
« Reply #6 on: 02 February 2009, 16:07 »
Cheers people , Will be looking forward to this i think ???   So how much pipe will i need - Gonna replace it all i think
Iam a real novice on the tools so please bear with me  :wink:
Offline golfnut8v
« Reply #7 on: 02 February 2009, 16:24 »
you have never done this before???
« Reply #8 on: 02 February 2009, 16:43 »
I had all the pipes made up and i still found it a pain. change the brake compensator too whilst your there £35 ish from gscp's. Best bet is to take the pipes off and get them made up, that way you won't have to flare them yourself.
Offline Grazy
« Reply #9 on: 03 February 2009, 15:50 »
Nope never done it before  :shocked:
Cheers Oakgreen , where could i get pipes made up ?? :cool:
