Golf mk2
Hazzards only flash one side
Topic: Hazzards only flash one side (Read 882 times)
boldy147
01 February 2009, 16:25 »
My hazzards only flash one side , i have checked bulbs and all ok , so assume its the wiring but i cannot get my head around the haynes manual . can someone please help thanks
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Hazzards only flash one side
01 February 2009, 17:34 »
id say its likely to be the hazard switch itself, or a loose connection to the switch stalk (depending if its pre/post 90)
DarnPB
Formerly Darnpistonbroke
01 February 2009, 19:37 »
Hazards relay??
rubjonny
10k hero
02 February 2009, 08:30 »
no there is only 1 relay output which powers both sides, so its not that. problem has to be in the switch itself. if its a pre-90 the switch is seperate from the stalks, if its a post 90 its built in.
Ben Lessani
The poor mans MK2 Haynes author
02 February 2009, 08:50 »
Mine was a loose wire on the back of the switch, caused it to flash one side and not the other.
Golf mk2
