Author Topic: 16v braking issues  (Read 1679 times)
Offline rob026
  • Mk3 16v GTI
16v braking issues
« on: 31 January 2009, 13:51 »
I have a 96 2.0 16v, when I apply the brakes I get a noise that sounds similar to a playing card in the spokes of a push bike, the pedal firms up, and really bad vibrations back through the pedal, this has actually started happening when im not applying the brakes as well, which is wierd, I recently replaced o/s abs sensor which didnt fix it altough when the abs sensors are disconected the problem went  :huh: any help would be muchly appreciated :cool:
Offline spunkymonkey
  • Tepidly moist! That's what that is!
Re: 16v braking issues
« Reply #1 on: 31 January 2009, 14:15 »
its obviously an abs fault. get in on a computer and see if anything shows up.
Offline mush
« Reply #2 on: 31 January 2009, 14:42 »
as above just get it plugged in dont waist any time on replacing parts that may not even need doing in the first place.
it will also read all your fault codes and tell you if theres a problem with anything else.
GSF charged me £10.00 to jack mine into the matrix and it came up x2 rear abs rings faulty. replaced and all is now fine. :cool:
MK2 golf 16v :-)
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 31 January 2009, 14:45 »
yeah it sounds like the abs is pulsing (working even without the brakes applied..this would normally mean a duff sensor!or two). time for vag-com and see what codes show up
Offline mush
« Reply #4 on: 31 January 2009, 14:50 »
before you have it tested make sure you connect what ever you disconnected is re-connected as this would be a waist of time other wise
MK2 golf 16v :-)
sharpie
« Reply #5 on: 31 January 2009, 14:50 »
rather than wasting time/money plugging it into a computer to determine whether or not it's the abs, pull the abs fuse and try it to see if it still does it.
could well be a warped disc.
Offline rob026
  • Mk3 16v GTI
« Reply #6 on: 31 January 2009, 17:39 »
VAG com it is thanks for your help guys :smiley:
Offline Khare
  • The bear that khares
« Reply #7 on: 31 January 2009, 17:43 »
sharpie read before you post.
sharpie
« Reply #8 on: 31 January 2009, 17:44 »
nah more time posting less time reading
