The garage
window problem
Topic: window problem (Read 2774 times)
kj
window problem
29 January 2009, 09:32 »
my window wont go up, it comes up half way and then goes back down??
thx in advance!
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: window problem
29 January 2009, 10:42 »
car?
kj
Re: window problem
29 January 2009, 10:48 »
voltswaggon golf 1996 1.6 75 bhp
rubjonny
10k hero
Re: window problem
29 January 2009, 11:04 »
right, the later models have a safety fdeature to wind em down if they think you got your head stuck in the glass, is the window stiff at all?
kj
Re: window problem
29 January 2009, 11:31 »
erm seems normal not too lose or stiff.
is it possible to wind it up, if so how cause i cant see any handle or anything.
thx
rubjonny
10k hero
Re: window problem
29 January 2009, 11:34 »
try holding the button down, or 'catching' the window as it starts to roll down again. its possible the 1 touch system has come out of calibration. Also i believe the MK3s can suffer from problems with regulator clips that hold the glass?
kj
Re: window problem
Reply #6 on:
29 January 2009, 12:07 »
ive tryd both and none workes. before it did this it used to do it but only every now and then and would come back up if i pressed it enough times but now only comes a quatre the way and goes back down.
rubjonny
10k hero
Re: window problem
Reply #7 on:
29 January 2009, 12:45 »
sounds like you need a new regulator then
kj
Re: window problem
Reply #8 on:
29 January 2009, 12:54 »
ok where is the regulator, also wat does it do thx.
rubjonny
10k hero
Re: window problem
Reply #9 on:
29 January 2009, 15:10 »
thats the bit that moves the window up n down, its behind the door card. if you take the door card off and watch the window while it tries to move, the problem may become obvious
The garage
window problem
