Author Topic: what does this do/ what isit for?  (Read 2777 times)
Re: what does this do/ what isit for?
« Reply #10 on: 29 January 2009, 10:39 »
yep those are for the electrically adjustible headlight range control.  as for the HID problem, it might be the dim-dip resistor thingy, its found near the driver side headlight, size n shape of a packet o polos.
Offline muppet
  • 1.8 16v Oak Green :D
« Reply #11 on: 29 January 2009, 11:54 »
so taking resister thingy out of the equation would help? lol how would i take it apart just pull the wire out?
« Reply #12 on: 29 January 2009, 12:45 »
possibly, good news is its dead easy to try.  follow the 2 yellow wires up from it and you'll find a 2 pin plug, disconnect this and bobs ya uncle :)
Offline danny_p
« Reply #13 on: 29 January 2009, 16:51 »
good pun but not as funny as ur help has been thanks
no worrys :P
btw  cheep chinky HID's have a habbit of not working properly.    there are easy fixes for some units
all the VW's have gone bar 1.
Offline muppet
« Reply #14 on: 29 January 2009, 21:58 »
thanks for that rubjonny ill try it later on or tomorrow  :smiley: hopefully it fixes the problem
Offline muppet
« Reply #15 on: 31 January 2009, 00:10 »
ok ive tried disconnecting that resistor but then the lights completly stopped working?!?!?!?! really confused now lol
Offline AdamMk2
  • Beautiful
« Reply #16 on: 01 February 2009, 20:02 »
Potentially if it doesnt blow the fuse for the lights Im thinking maybe it could be related to the transformer unit provided.
I believe it generates a start up current of 23,000 volts then drops significantly back to a normal lower voltage.
They obviosly start up because you said they run for a small amount of time.
This is assuming you
1. start your engine
2. turn on the lights
in this order as obviously dipped doesnt work without turning the ignition on anyway and the current needed requires the engine to be running.
when you start them up you should get quite a significant pulse at the start then they dip and ignite.
Have you upgraded your loom also because I wopuld suggest thats also a good idea for the start up current.
Ad
Offline muppet
« Reply #17 on: 02 February 2009, 00:32 »
thanks for that Adam, at the moment ive left the wiring as it was working more than fine on another hid kit my mate had in it before! but i have to admit he did pay sh*te loads for his kit!
ill give it another go tomorrow hopefully if it stops snowing for long enough!
thanks for the help guys :grin:
Offline ozegti
« Reply #18 on: 14 February 2009, 20:30 »
no worrys :P
Some people might take offence to Chinky. For instance me. PLease refrain from using this word as it's very derogatory and just plain rude and uneducated.
I had the same problem, but it was a duff ballast. Not sure how to check if they're working properly, but I swapped a ballast in from another set of Hids. Work fine now, but I have a spare which is annoying.
