Author Topic: Exhaust Sound  (Read 2576 times)
Offline Dan34
  • VTEC Powerzzzz
Exhaust Sound
« on: 28 January 2009, 18:19 »
Right heres my problem when i bought my gti 8v it sounded like a tractor really bad ticker sound on idle, which i thought was a front silencer blowing. Wasent a problem as i was gonna put a new full system on anyway. But now i have the system on and my car still sounds like a tractor, has a bad ticker/blowing sound coming from the front end of the car, the sound is worse from cold. I think this could be causing my car to have a lumpy idle
but my question is, it is the manifold blowing or something else?
i have used the search function but doesnt really give me the right answer
Thanks
Dan
Offline Mk2George
Re: Exhaust Sound
« Reply #1 on: 28 January 2009, 18:29 »
Could be the manifold and/or the downpipe from it by the sounds of it. I take it you replaced the exhaust from the downpipe back?
Cant remember if the 8v has a 1 piece manifold to centre section, I know the 16v doesnt but its been a while since I put and exhaust on an 8v
VeeDubGTI16v
Re: Exhaust Sound
« Reply #2 on: 28 January 2009, 18:29 »
put your hand over it, its easy to tell
Offline Dan34
  • VTEC Powerzzzz
Re: Exhaust Sound
« Reply #3 on: 28 January 2009, 18:33 »
yeah my system was from manifold back i think il have to have good ol route about and see if i can spot any leaks, just anoying i aint got no rampa to put it on  :cry: ah well...
Dan
Offline richard s
Re: Exhaust Sound
« Reply #4 on: 28 January 2009, 20:26 »
i changed my down pipe and have a tinny blowing type noise and it seems to be around where the pipe goes from 2to1 and i have had mine on a ramp and checked it
only thing i can think of is to heat wrap it to try and reduce the noise
but check for blowing just to make sure
Offline Mr Blue
Re: Exhaust Sound
« Reply #5 on: 28 January 2009, 20:33 »
are you sure its not a mechanical problem and not just an exhaust leak?
Like above. Cover the exhaust tip and listen out for a 'hiss'
You may have an air leak. Check the rocker cover bung that seals the air breather to the rocker cover.
could also be a broken manifold stud. Had this before
« Last Edit: 28 January 2009, 20:36 by Mr Blue »
Offline Dan34
  • VTEC Powerzzzz
Re: Exhaust Sound
« Reply #6 on: 28 January 2009, 21:08 »
cheers thats what i was thinking too hoping its nothing too serious will have a look soon as poss
Thanks Dan
Re: Exhaust Sound
« Reply #7 on: 29 January 2009, 10:36 »
could be the timing is out, i tuned up a digi gti the other week that sounded like that, guy had changed his zaust since he thought it was blowing.  turned out the cam was out a tooth and the ign was out a country mile...
Offline Rodriguez
Re: Exhaust Sound
« Reply #8 on: 29 January 2009, 11:09 »
Mine sounds pretty 'throaty'.  No leaks, I'm wondering if a baffle's gone.
Any other symtpoms of bad timing RJ?  Idle and power are excellent at the mo.
Offline sidecarphil
Re: Exhaust Sound
« Reply #9 on: 29 January 2009, 11:12 »
or a loose spark plug :)
