Author Topic: Replacing Backrest  (Read 1578 times)
Offline maxp
  • J reg 8v digi gti
Replacing Backrest
« on: 28 January 2009, 14:31 »
If i want to replace the backrest section of a drivers seat is it possible and how much faffing is there involved?
Also is it possible to transplant the passenger backrest section to the drivers?
This is for a 5dr gti with ranbow theme
« Last Edit: 28 January 2009, 14:33 by maxp »
Re: Replacing Backrest
« Reply #1 on: 28 January 2009, 16:23 »
easy and yep no problem. only issue is the backreast angle adjust knob is on the wrong side.
1st off pop off the 2 plastic trims, look close and you'll see 3 pegs, push them thru and the trims come off.  next tilt the backrest forward, you'll see 2 hooks right at the base of the seet release those and tilt the seat.  Then just release the clip on either side that the backrest pivots on, and youre done!
Just be aware pre & post 90 seats are slightly different so make sure the donor seat is the same as whats fitted :)
Offline maxp
  • J reg 8v digi gti
« Reply #2 on: 29 January 2009, 00:20 »
Sounds encouraging. Are you sure the backrest angle ajust knob cant be swapped to the other side?
Offline GolfRider
  • Take me to the Golfy shop =)
« Reply #3 on: 29 January 2009, 02:35 »
plz guys how can i post a new topic :$
GoLF-_-RiDeR
Offline maxp
  • J reg 8v digi gti
« Reply #4 on: 29 January 2009, 09:12 »
On the topic listings page there is a text link that says 'new topic'
Offline Gloves88
« Reply #5 on: 29 January 2009, 09:16 »
I thought it could....the adjustment knob it on a long thin bar that slides all the way through the seat, pretty sure if you just slide the bar through from the other side it'll work....correct me if i'm wrong
« Reply #6 on: 29 January 2009, 10:40 »
not something I've ever tried, but while the backrest is off you could have a look eh ;)
