Author Topic: How to change bulbs on clocks in dash?  (Read 2036 times)
Offline billy_vw
« on: 27 January 2009, 17:21 »
How easy and does any1 have any guides on bulb replacement on dash/clocks?
Ta
Billy
MK5 GT TDi
kells
Re: How to change bulbs on clocks in dash?
« Reply #1 on: 27 January 2009, 17:50 »
very easy, 10 mins to do
remove headlamp switch, theirs a tab u push inwards once you remove ABS light panel
remove the trim to the right of the stereo, where the heated seat switch is on yours i think, this hides a screw, undo that and the ones behind the headlight switch then the surround round the clocks pulls off, you may need to remove the steering covers too (ones round the ignition etc)
the clocks themselves are held in via 2 screws, un do these and they tilt forward, bulbs are twist fit under a cover on the top, its easier to remove the clocks from the car, just reach behind and un plug the connector (its on the left side) then pull the clocks out
very simple once you get going
Offline Andy-H
« Reply #2 on: 27 January 2009, 19:02 »
Are you wanting to change the colour ?
If so, you'll have to take the green filter out of the top as well.  :smiley:
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline billy_vw
« Reply #3 on: 14 February 2009, 12:16 »
Finally got round to doing this today, great help Thanks  :wink:
MK5 GT TDi
Offline leegt5
« Reply #4 on: 27 February 2010, 17:54 »
My MFA/clock lcd panel isn't lighting up is it just a matter of changing a bulb or are the lcd panel ones lit up by leds soldered to the circuit board ?
kells
« Reply #5 on: 27 February 2010, 18:50 »
some have a bulb for each display others like mine are soldered in, dails out and look at the rear will tell you which you have
Offline Khare
  • The bear that khares
« Reply #6 on: 27 February 2010, 18:54 »
what bulbs are needed? I wanna change the color at some point.
Offline ian24driver
« Reply #7 on: 28 February 2010, 09:56 »
i took the bulbs out of mine, then went to the vw dealer but you may get them from auto factors. Cost me £1.50 a bulb i think, i changed both while i had it out as its sods law the other may go soon.
Offline leegt5
« Reply #8 on: 28 February 2010, 19:07 »
Yeah mine was a bulb one for the MFA lcd screen and one for the Odometer. So I replaced both.. Didn't want one brighter than the other or the other one go and have to get the dials out again. Cost £3.00 for 2 bulbs from motor factor.
Offline Khare
« Reply #9 on: 28 February 2010, 19:23 »
I want to get them in either white, or blue.
