Author Topic: The ultimate tappet thread  (Read 27723 times)
Offline DarnPB
  • Formerly Darnpistonbroke
mmmmmmmm merlin engine  :drool: :drool: :drool: :drool:
27 litres and 2500bhp of pure grunt. And all from a single SU carb with Miss Schillings oriface.
Offline sidecarphil
yeah 27ltrs of torque  :drool: :drool:
and we talk about torque increase using a 2.0 bottom end instead of a 1.8
Offline Ben Lessani
Been reading about this gauge business, useful info here.
I was going to pinch the gauge off my step dads Audi Coupé to test it, but the oil pressure sender is pretty inaccessible - I'll have to remove a bunch of coolant pipes etc. to get to it, so thats not an option.
I'm going to have to go on the hunt to get a gauge for myself. Anyone have a list which shows what models sported them, so far all I know is Audi Coupé ...
Offline Ben Lessani
Well, I got my mits on a gauge, abeit an industrial one and I have some really perculiar results. I'm trying to diagnose what is going on, so heres what I can confirm.
I've uploaded a recording of the engine running, listen to my tappets here
When engine is cold, cylinder pressures are:
1. ~12 Bar
2. ~12 Bar
3. ~12 Bar
4. ~12 Bar
When the engine is hot (90 C oil temp), cylinder pressures are:
1. ~11.5 Bar
2. ~11.5 Bar
3. ~11.5 Bar
4. ~11.5 Bar
Cyl Head cold engine oil pressure 1000RPM ~4 Bar
Cyl Head hot engine oil pressyre 1000RPM ~3 Bar
If I rev over 1500RPM the gauge maxes out at over 5 Bar
When I turn the key to IGN, oil pressure light flashes
When engine is running, oil pressure light is off
If I ground the blue wire to the head oil pressure sensor, the light flashes on the dash
If I remove the wire going to the oil cooler pressure sensor, nothing happens
When the engine is running, the sensor is grounded
When the engine is running the wire going to it, is 12V
Spark plugs are black around the base and grey at the tips
Exhaust was smokey, but did not smell of burning oil, car also hadn't been run in 2 days (photo taken immediately after starting)
« Last Edit: 17 February 2009, 09:53 by Ben Lessani »
Offline sidecarphil
i'm lost with it mate
just wonder if you have a dodgy set of tappets ??
i am really at a loss for you sorry :cry: :cry:
Offline Ben Lessani
I've emailed the seller and I am trying to see if he will do me an exchange.
Did you listen to the audio I uploaded, does that sound like every tappet - or just 1/2?
All this faffing about makes me a sad panda :cry:
Offline sidecarphil
are you sure it is the tappets ??
sounds funny really !!!
not sure it is the tappets though , maybe just one noise  :undecided: :undecided:
very strange fella
Offline Ben Lessani
Yeah, the recording isn't really an accurate represenatation, but its better than trying to explain.
Offline Khare
  • The bear that khares
sounds like my mum using the sowing machine :tongue:
id try a different set of tappets and give the cam and cam bearings a good check over.
Offline sidecarphil
are you missing any sockets or a nut  :laugh: :laugh:
