Author Topic: The ultimate tappet thread  (Read 27765 times)
Offline Ben Lessani
Not sure whether I posted or not, that was the nick of the inside of the rocker cover. There was no contamination anywhere else, not even on the baffle. It could be unrelated, but worth a mention.
With regards to the pressure, I've never had the light come on, and my journeys about include some fairly hard right turns with no sign of low pressure, no light, no buzz.
The ATF will be my last(ish) resort, after the pressure test anyway. Its got me well and truly baffled.
Offline sidecarphil
i've always removed tappits with a magnet and so far no problems  :undecided:
you learn something every day huh  :shocked:
Offline danny_p
seen what happens  if a cam gets magnitised,  that is scary   but it had been stuck to an i beam for months with a big f off magnet
all the VW's have gone bar 1.
Offline mattkh
Hi
I am learning so much from this thread.
Going back to basics, is the tappet noise the one caused when the valve edges hit the seats on the cylinder head or is it something different.
Offline danny_p
it's caused by the gap between the tappet and camshaft,  if the gap is to big the cam hits the tappet when it lifts the valve whears if it's correct  the valve will sit on it's seat firmly but the cam and tappet will make contact before the cam starts trying to open the valve,  ( with mecanical tappets )  hydralic ones do pritty much the same job  but tend to stay incontact with the cam but compensate  for wear tempriture ect  untill they themselves wear or block,   big bounus with them is no fecking about with screwdriver thou gadge and spanner settign the bastards up
Offline mattkh
Hi
Thank you.
In that case, Ben's problem must be the cam timing or incompatible tappets.
Offline danny_p
 for some reason the tappets arnt wanting to take up the clearance when hot,  thats something else
Offline DarnPB
  • Formerly Darnpistonbroke
Hi
Thank you.
Cam timing will not cause the tappets to be noisy.
Offline sidecarphil
could do if it was a long way out
but then there is a BIG problem
this isn't his problem
does sound like an oil pressure problem when it warms up , but why is a mistery at the moment :undecided:
Offline DarnPB
How? :huh:
Tappets take up the gap between the valve and the cam. Doesn't matter how far out the cam timing is. Any noise will be catastrophic destruction as the valves hit the pistons or pinking and back firing. Tappet noise...er no!
