Author Topic: The ultimate tappet thread  (Read 27674 times)
Offline sidecarphil
tip top fella
think this must have been the longest thread i have EVER read/written in LOL
fingers crossed for you
but i am with RJuk1982 on the forte theory with the blocked oil feed to a tappet
Offline Ben Lessani
I guess I'll never really know what caused it - I've changed/replaced and messed with so many things - its definately a tricky one.
But at least we've got a solution for other people with noisy tappets - refurb tappets, replace tappets twice after, flush oil with atf, change oil and filter, clean pickup and replace rocker and sump gaskets.
I think I'm going to start my own MK2 golf timing belt replacement service. I can get one off in the dark in about 5 minutes now.
Offline Khare
  • The bear that khares
well done dude. glad to hear you got it sorted.
Offline Ben Lessani
2 weeks on and silent as the night, hells yeah :laugh:
Offline Khare
Offline OakeyDoak16v
Phew. :smiley: Nice one! :wink:
Offline sidecarphil
thank god , glad it is sorted fella
this thread will need its own server soon  :grin: :grin:
Offline Ben Lessani
Lol! As long as I keep bumping it with pointless replies :rolleyes:
Offline sidecarphil
Offline Ben Lessani
A hydraulic lifter, also known as a hydraulic tappet or a hydraulic lash adjuster, is a device for maintaining zero valve clearance in an internal combustion engine. The conventional means of adjusting valve actuation always requires a small clearance to be left between the valve and its rocker or cam follower to allow for thermal expansion and wear. The hydraulic lifter was designed to ensure that the valve train always operates with zero clearance, leading to quieter operation and eliminating the need for periodic adjustment of valve clearance.
The hydraulic lifter consists of a hollow expanding piston situated between the camshaft and valve. It is operated either by a rocker mechanism, or in the case of one or more overhead camshafts , directly by the camshaft. The lifter is filled with engine oil intermittently from an oil galley via a small drilling. When the engine valve is closed, the lifter is free to fill with oil. When the valve is opening and the lifter is being operated by the camshaft, the oil feed is blocked and the lifter acts just as a solid one would, oil being incompressible.
History
The first firm to include hydraulic lifters in its design was Pierce-Arrow in the early 1930s. Hydraulic lifters were popular on automobiles designed in the 1980s, but most newer cars have reverted to bucket-and-shim mechanical lifters. Although these do not run as quietly and are not maintenance-free, they are cheaper and rarely need adjustment because the wear caused by operation is spread over a large area.
Disadvantages
There are a number of potential problems with hydraulic lifters. Frequently, the valvetrain will rattle loudly on startup due to oil draining from the lifters when the vehicle is parked. This is not considered significant provided the noise disappears within a couple of minutes, typically it usually only lasts a second or two. A rattle that does not go away can indicate a blocked oil feed or that one or more of the lifters has collapsed due to wear and is no longer opening its valve fully. The affected lifter should be replaced in the latter circumstances. In extremely rare circumstances, a lifter can "pump up" and create negative valve clearance so that its valve cannot close. This is more serious as burnt valves will result. In all cases it is important to follow the manufacturer's recommendations for oil viscosity and quality.
... thread relevant and makes me nuuuummmmbeeerrr oooonnne! :laugh: :laugh:
... I've stopped now.
« Last Edit: 05 March 2009, 10:41 by Ben Lessani »
