Author Topic: play in steering wheel??  (Read 1172 times)
Offline serafumi
« on: 26 January 2009, 11:45 »
i seem to have a bit of up and down play on my steering wheel, i believe it to be coming from the bearing on steering column . has anyone ever changed these if so is it a hard job?
cheers chaps
Offline muppet
  • 1.8 16v Oak Green :D
Re: play in steering wheel??
« Reply #1 on: 26 January 2009, 11:47 »
sorry to jump in but i have the same problem but its not that bad, just slightly noticable on mine!!!
Offline serafumi
« Reply #2 on: 26 January 2009, 12:02 »
no worries about jumping in . mine is only noticeable when you grab the wheel and lift it up and down. lets hope we get an answer
« Reply #3 on: 26 January 2009, 12:49 »
i had this on mine, a new upper bearing did not help (its part of the lock housing, so you need to replace the whole thing) this play disappeared after i converted to PAS so it was either the UJ or the rack :)
if you can swap your lock housing then give it a try by all means, main problem is most MK2s have the spline adaptor on there which makes it hard.
Offline muppet
« Reply #4 on: 26 January 2009, 13:41 »
my mk2 has pas but is there a diffrence between PAS and just normal power steering then? thanks
« Reply #5 on: 26 January 2009, 15:07 »
same thing really, PAS stands for Power Assisted Steering :)
You could say that some cars have power steering (realy, really light and horrible feeling), whereas a MK2 has power assisted, as its not really noticable unless you're parking.  At least I found the weighting to be almost the same when driving along between my manual rack and the 16v PAS rack I replaced it with!
Offline richard s
« Reply #6 on: 26 January 2009, 20:24 »
i had play in mine and it turned out to be the clamp bolt was missing so have a look at this first
« Reply #7 on: 27 January 2009, 11:32 »
ah yes, good one that for working loose!
