Author Topic: My squealing squeaking brakes!!! WHY?  (Read 18493 times)
Offline ub7rm
Re: My squealing squeaking brakes!!! WHY?
« Reply #10 on: 26 January 2009, 13:48 »
The garage I use for servicing takes the pads off and deglaze them as part of the service.
have you actually witnessed that for yourself? never ever heard of a garage doing that
No never seen them do it, its itemised on the bill. I have used them for a few years and they have never been anything other than scrupulously honest.  They deff take the pads off as I can see the fresh copper grease.  The brakes do feel a little sharper too but that could be a placebo.  Its a little garage run by a father and son and they are quite old fashioned in some ways.....like you don't pay when you pick up your car, they send you a bill a month later!
2020 BMW 128ti
2017 Golf GTD Estate
Offline KentBladeboy
« Reply #11 on: 26 January 2009, 15:06 »
If your pads are glazed from new, it is very hard to cure, its the resin in the new pads overheating and turning to gas, which then sticks to the surface of the pad   ie glazes it.
You can take the pads out and use something abrasive on them like a file, but more often than not the problem reappears, had this many times on racebikes.
Its all down to correct bedding in of the pads from new.
05 GTI DSG, Steel Grey,Monzas,Xenons,Leather etc.,  SOLD
Offline SteveS
  • GTI ED30
« Reply #12 on: 26 January 2009, 19:23 »
mine do it, tried breaking hard, no luck.. its horrid
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline R32UK
« Reply #13 on: 26 January 2009, 19:40 »
Exact same problem here mate! Got really bad at one point just before it went in for a service, but when I got it back it was fine for a couple of weeks. Now its beyond a joke... almost to the point of embarassment :embarassed:
Will try the hard braking technique tonight to see if it improves anything. Did get my mechanic to have a quick check to see if the pads are worn down and he has said they will be ok for a while...  :undecided:
Offline Emeye
« Reply #14 on: 26 January 2009, 21:54 »
I'm really interested if this heavy braking cure works. Luckily I live not far away from the local racetrack, er I mean bypass :laugh: and I use it everyday to get to and from work so not expecting any brake squeeling!  :grin: But my mate had this issue with his classic scooby and the heavy braking really worked!  :smiley:
Offline wellzee
« Reply #15 on: 27 January 2009, 02:14 »
I have the same problem too, only when coming to a stop from speeds around 30mph ish. Mine was in for a service last week and they told me my car was in 'perfect' condition - not even any advisory items and that the squealing was not due to pad wear. its really frustrating me, as i'm sure it is all of you. let me know how the hard breaking goes!
Black 08 GTi - 18" Monza II's, Leather, Centre Arm Rest, Parking Sensors - Love It!
Offline synnea
« Reply #16 on: 27 January 2009, 08:24 »
Interesting to know that is not just me then. I didnt get a chance last night to try the braking as the roads were busier than normal so I will make a point to go out late tonight to try it and let you all know.
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
Offline AlanD
  • MK5 2.0T 16v
« Reply #17 on: 27 January 2009, 09:07 »
Im shocked at how many people are having this problem. Clearly this is a design flaw of some sort.
Offline R32UK
« Reply #18 on: 27 January 2009, 09:50 »
Still squeeking!
Tried the braking thing on the way home last night, but again it was a little too busy to do it to the full extent. Braking from what kind of speeds are we talking? and should I be braking til stop?
thanks
Offline Teutonic_Tamer
« Reply #19 on: 27 January 2009, 12:21 »
My R32 for the past 3 weeks has had terrible issues with the brakes squealing as I come to a halt. Happens most when slowing from 30mph down to a stop in the wet and dry.
As others have said - a common fault at this time of the year - particularly if the roads have been salted.  It is basically the brake pads seizing in the calipers - due to a variety of reasons.  Do you park your car outside, or in a garage?  Garage parking can actually make the problem worse.  A good tip is to get a pumpy uppy garden sprayer, keep it filled with plain water, and when you get home each evening, let the brakes cool down for ½hour, then spray water all over the discs, pads and calipers - and this should wash the salt away.
The car was in for a service last Thursday and I explained to them the problem at my local dealer. The service guy advised me that the brake pads would be changed if needed.
A "service" is just a visual inspection of the brakes, so no dismantling or cleaning is carried out on them.  If you did specifically make it clear that you also wanted them to check out the specific problem, then this would be work charged at an additional cost (but which can be claimed under warranty).
On picking the car up I was told the brake pads were no where near needing changing. On hearing that I asked them well what is causing the squeaking of the brakes when I slow down to a stop. His reply was 'dust'. I assume he meant brake dust.
"Stock" answer which seems to be prevalent by the majority of monkies employed by main stealers these days . . .  :rolleyes:  Whilst a build up of brake dust may cause brake squeal - 99% of the time (on non-drilled and non-floating discs), it is caused by the pads seizing in the calipers.
On driving home I thought that this 'dust' would have been cleared as part of the service but the squeaking of brakes is still there! It is now getting to the point that I cant bare it. My car never did it before until about 3 weeks ago. The service has made no difference unless there is something they havent done.
As above, a service alone wont do anything to rectify this specific problem (actually, a service wont rectify ANY problems - because "services" are not "diagnostic" operations).  But if you are sure you specifically asked them to investigate "squealing brakes" or similar - then the stealer has failed you.
Can any over you shed some light if you have had this issue with any MK5 golf whether R32 like myself or GTI/ED 30 etc. I was about to phone my service dept back to tell them I still have the problem but wanted some opinions from here first. Any of you any idea of a cause and/or a fix? Thanks.
Are you good with spanners?  And don't mind working on your brakes?  If so, get hold of some NICKEL based anti-seize compound.  Cromwell Industrial Supplies over the counter branches - find them on www.Cromwell.co.uk - sell some stuff called "Bostic Never-Seez Pure Nickel Special - NSN165" (they may have to order it from their central depot in Wigston).  It is about £30 for a 1lb tin, but will last for years.  Others have recommended using copper based anti-seize greases, but most are shyte, and will wash off very quickly - not a prob if you live in Dubai, but shyte in Blighty.
Strip your brakes down, clean all the rust, dust and general crud from the pads and calipers - taking particular detail with the "hammer heads" on the pads, the grooves in the calipers where the hammer heads slide.  Also clean the inside of the brake piston, and the contact surfaces of the pad back plates.  Then smear anti-seize paste on all the metalic sliding parts (the hammer heads & back plates of the pads, the contact face and the inside groove of the piston, and the pad grooves and contact surface of the caliper), and reassemble.  As a rule of thumb, for each individual caliper, between one and two "pea-sizes" of anti-seize paste should suffice - any less, and it is likley not to be effective - and any more, and it will just get wasted.
Do NOT use any petroleum based grease or oils (copper grease, nickel grease, lithium grease, WD-40, etc) on ANY rubber components - particularly the caliper piston rubber dust seal, or the caliper rubber bushes for the slide pins.  You must only use a generic silicone grease (Rocol AquaSil - also from Cromwell), or a specific "brake rubberlube" grease (which may be either silicone or a highly refined lithium grease) such as "Delphi/Lockheed Rubberlube".  If you use incorrect greases on these areas, the petroleum content attacks the rubber, and causes it to swell, disfigure, and eventually rupture.  This can ruin the caliper piston bore (through the ingress of grit), or cause the brakes to bind (where the rubber bushes swell on the sliding pins).
HTH
I feel like a homo
