Golf mk2
Sagging front big bumper
Topic: Sagging front big bumper (Read 1645 times)
Justins145bhpMK1
25 June 2004, 14:39 »
my mk2 has a saggy front big bumper, its an original big bumper model.
its looks as though the edges are drooping down. Any ideas to correct this.
Gambit
Forum addict
Re:Sagging front big bumper
25 June 2004, 15:22 »
take it off and replace the brackets on the side of the wing with new items
Veedubgt18v
Guest
26 June 2004, 16:14 »
it may not be the brackets it could be the clips inside the bumper where it clips onto the wing support. you may have to fabricate some or get some from a scrappy. i know vag ones are screwed on but pattern ones and plastic welded on
Dizzie
Forum addict
Make friends with your fast
26 June 2004, 18:26 »
mine are plastic welded on. do you know if you can buy just the C bracket and rivot/screw it on to replace them?
Mk2 Golf GTi restoration -
https://youtu.be/s-Jj5bABxM8
Blue MK2
Guest
26 June 2004, 19:32 »
Take the bumper off and you can adjust the way it sits on the car by the brackets. The bolts will be rusted so abit of WD40 and you should be alrite.
well on mine you can
Golf mk2
