Author Topic: difference tyre size makes  (Read 921 times)
Offline player.777
« on: 25 January 2009, 18:07 »
On the monty2s, I have 205/55 R16s.  I reckon the car would look a lot better if the tyre wall was smaller- 50, or 45.  If I put 205/45/R16s on, what difference would that make to anything- The rolling radius would be smaller so would that mean the speedo would be out?  The car would sit nearer the ground too?  what else?  Has anyone else changed the wall size- notice any difference? how does the car look?
Offline Steve_PD
Re: difference tyre size makes
« Reply #1 on: 25 January 2009, 18:15 »
it would lower your car by about 20mm, your speedo will be out and you'll accelerate quicker  :undecided: possible tyres will be more expensive due to not being common  :undecided:
I wouldn't do it purely because of the speedo
Offline player.777
« Reply #2 on: 25 January 2009, 18:20 »
yes thats what I'm thinking too mate.
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #3 on: 25 January 2009, 18:28 »
I wouldn't do it (well maybe if 50 profiles weren't so expensive, I might??).  Have a play with this:-
http://www.miata.net/garage/tirecalc.html
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
« Reply #4 on: 25 January 2009, 18:29 »
ps  You don't really want to be straying from +/- 3%. ;)
Offline player.777
« Reply #5 on: 25 January 2009, 18:53 »
Thanks mate- good little toy that. Ok, think I'll stick to the normal size then. thanks
