Author Topic: Air intake/induction kits?  (Read 5238 times)
Offline th3_f15t
« on: 25 January 2009, 10:38 »
Hey there. I recently went from owning a (mint condition) Ford Fiesta Si 16v to owning a (very good looking) Golf GTI 8v.
Now, with my Fiesta, I was always told that a full induction kit (cone filter, pipes and new cool air feed) should not be used unless a proper tune up was done, as the old 16v engines suffered with the forced air coming in.
But my Golf GTI 8v already has one on there, but with no other modifications (stnadard ECU mapping, steel exhaust ect...). Should I put the original air box and K&N pannel filter in instead, to gain better air flow? New to VW engines so not too sure!
Many thanks.
Moving over to Flickr, sorry for the broken picture links!
Offline LazyLunatic
  • MK3 20VT Project
Re: Air intake/induction kits?
« Reply #1 on: 25 January 2009, 12:19 »
dont think induction kit will force in enough air to cause the engine to suffer. these engines are bomb-proof :D
i dont have an 2.0 8v but i think most people on here that own them use the original airbox and a K&N panel filter for the best performance.
LL :)
Offline th3_f15t
« Reply #2 on: 25 January 2009, 12:39 »
Forgot to mention, it's a Mark II 1.8 litre 8 valve engine. Wondered if it made a difference and if so, might upgrade to a K&N induction kit reather than the random one it's got on it now.
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 25 January 2009, 18:45 »
Stick the standard airbox and an uprated panel filter on and don't waste your time with tat like 'induction kits'.  If you're going to modify it, do it properly and stick a 4-branch on the back, a bumpier cam and get it chipped.
Offline Neo Badness
  • Feet are for pedals
« Reply #4 on: 25 January 2009, 19:15 »
Welcome to the dub side... :grin:
Yeah, an cone filter makes it a bit throatier, maybe bit sharper throttle response but I think it's mostly subjective. I've had both and my current mk2 has a healthy induction roar as is compared with my old mk3. I'd recommend BMC's, bit pricey but the noise and definate noticeable improvement make em a good bet. Couple that with a better exhaust to start with and then go from there, depends what you want. Ported/flowed head, chipped, 2ltr bottom end, cam, quick shift, clutch. Go on, batter that visa card.... :laugh:
Offline th3_f15t
« Reply #5 on: 26 January 2009, 09:26 »
LoL, cheers guys. Going to try and get hold of a standard air intake system, clean it up and put a pannel filter in it. When I get enough money, may tune the engine, or might save the cash and buy a 16v and do that up... he he he.
  • Opinions я Us
« Reply #6 on: 26 January 2009, 14:50 »
The other things to bear in mind about 'induction kits' is that if there's a 'hot wire' MAF sensor in the intake, the oil used on the cone filters can contaminate this and trash it.  Also, engines are set up to scavenge warm air off the exhaust manifold when they are running cold.  Junking all that will likely damage cold running.
Time and again this question is asked and the response every time is 'makes a nice noise, but does nothing'.
Offline AudiA8Quattro
« Reply #7 on: 26 January 2009, 17:04 »
The engines are set up to draw hot air off the exhaust manifold when the air inlet temperature gets too low, its not actually there to help the engine warm up. I would stick with a k&n panel with a drilled box, always worked for me!
Offline Neo Badness
« Reply #8 on: 26 January 2009, 22:27 »
Drilled box with K&N panel filter is best of both worlds..... But since you mention it....I'll be selling a low mileage(110k) KR engine with full service history and all the ancilliers in next few months if you're interested? Has a standard airbox on it :grin:
Offline GMatthews86
« Reply #9 on: 30 January 2009, 12:35 »
i recently bought a mk2 8v for 400 but later realised it had no filter box.... i have ordered a powertec stainless steel induction kit. and will be installing next week. any advice criticism or applause. also will a tube from the front grill be sufficirnt to keep cool air going into the kit??
